Overlapping rotating domains using AMI in OF6 |
December 13, 2018, 08:37 |
Thomas Sprich
Rep Power: 11 |
Dear OpenFoamers,
I seem to remember reading that OpenFoam 6 could handle overlapping rotating meshes using AMI, but cannot verify or find anything regarding this when I search now. Does anyone know if this is possible in the new releases of OpenFoam or OpenFoam-dev? I found this post which provides a possible method of doing this which I will have to read and understand more thoroughly: Dynamic Mesh for a Gear Pump And this page where someone else had a similar problem: Overlapping AMIs but was referred to the link above. I have read the release notes for openFOAM 4 - 6, but can't see anything there either. Does anyone have any more information/advice on how to tackle this sort of problem. Sorry if these questions should have been posted the above threads. I didn't want to resurrect old threads. Thanks, Thomas |
December 13, 2018, 08:48 |
Peter Baskovich
Rep Power: 12 |
Maybe something like overset mesh?
https://www.openfoam.com/releases/op...6/numerics.php |
December 13, 2018, 09:15 |
Thomas Sprich
Rep Power: 11 |
Hi Pete,
Yes, that is what I was looking for. I'm going to try see if I can get that running tomorrow. Thanks very much for your help. Thomas |
December 17, 2020, 05:03 |
mengge
Rep Power: 6 |
Hi there,
I just learned a little bit about the method to handle the problem of solid body motion in OpenFOAM, and I'm going to try with overset meshes. However, since I've got some modified solvers based on OF6, I'm wondering if OF6 can deal with overset meshes? As far as I know it is not possible, can it? Thanks very much! |
December 17, 2020, 06:59 |
Thomas Sprich
Rep Power: 11 |
Hi mengge,
I would not expect it to work with OF6. overset is only available in ESI openfoam (www.openfoam.com). Regards, Thomas |
December 17, 2020, 07:11 |
#6 | |
mengge
Rep Power: 6 |
Thanks for your reply.Then I guess I will have to modify the solvers. Best regards, mengge |
ami |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
Translating and Rotating AMI | HiddenSquid | OpenFOAM Pre-Processing | 1 | October 25, 2017 03:59 |
Car external aerodynamic with wheel spinning issue | hokhay | FloEFD, FloWorks & FloTHERM | 2 | August 18, 2016 04:23 |
[mesh manipulation] Combining two meshes for AMI of rotating turbine | mahtin360 | OpenFOAM Meshing & Mesh Conversion | 0 | October 2, 2014 03:06 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
