Openfoam adding torque and thrust to certain cells |
Christophk
Rep Power: 7 ![]() |
for my simulation I need to add torque and thrust to certain cells. I set my mesh up, so I got those cells and need to add these volumeForces there and I don't have any idea, can anyone help me? |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
So you have the cells already defined as cellSets?
fvOptions is your friend. |
Christophk
I have the cells as cellZone.
Is there any tutorial on how to do it like syntax etc? |
Lucky
There is a bad example in:
Coded Source You need to change selectionMode from all to cellSet and add another line to give the label to the cellSet: Code:
type coded; selectionMode all; fields (h); name sourceTime; Code:
type coded; selectionMode cellSet; cellSet bananaSet; fields (U); // possibly others name sourceTime; Code:
heSource[i] += 1e5*sin(200*cellx[i])*V[i]; |
Calculation of thrust and torque for propeller | aeksberde | OpenFOAM Post-Processing | 2 | October 28, 2019 05:23 |
Propeller Thrust and Torque Increasing | KindaHungry | STAR-CCM+ | 1 | November 3, 2018 05:59 |
How do I find thrust and torque for a propeller in ANSYS Fluent ? | Hayatul_Maruf | FLUENT | 0 | May 14, 2018 00:05 |
how to get thrust and torque from fluent acting on propeller using single enclosure | Naveen Kumar Gulla | FLUENT | 2 | April 12, 2018 07:59 |
calculate the thrust and torque of a propeller in open water condition. | Alex song | STAR-CCM+ | 14 | August 3, 2016 11:54 |
