interFoam/interIsoFoam - transient water jet - high velocities at interface |
December 6, 2018, 08:07 |
Rep Power: 9 |
I tried to model a transient water jet inspired by the archerfish using ILES in OpenFOAM v1806 with MULES and isoAdvector.
I get very high velocities in some cells at the interface which are higher than the biggest inlet velocity (6 m/s). There are also oscillations behind the jet. I can get rid of those effects by using RANS. But a lot information about the jet shape gets lost. There are also oscillations in my DES case. It seems that these oscillations get affected by surface tension. How can I improve my LES results? Thanks! |
interfoam, interisofoam, jet, les, multiphase |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 19:02 |
Two phase simulation - velocity of water above air-water interface isn't zero | Zeljko | CFX | 4 | February 27, 2018 16:45 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
High velocities interface with compressibleInterFoam | micpage18 | OpenFOAM Running, Solving & CFD | 0 | November 15, 2013 17:21 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
