unable to solve problem using SimpleFoam. Error showing in setting boundary condition |
Pawan Sharma
Rep Power: 7 ![]() |
hiii i was trying to solve my problem using SimpleFoam. The below attached error is shown,help me out please.
kuldeep@kuldeep-HP-15-TS-Notebook-PC:~/OpenFOAM/kuldeep-6/run/symmetric$ simpleFoam /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 6-d3fd147e6c65 Exec : simpleFoam Date : Dec 04 2018 Time : 22:56:36 Host : "kuldeep-HP-15-TS-Notebook-PC" PID : 1503 I/O : uncollated Case : /home/kuldeep/OpenFOAM/kuldeep-6/run/symmetric nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 --> FOAM Warning : From function entry::getKeyword(keyType&, Istream&) in file db/dictionary/entry/entryIO.C at line 96 Reading /home/kuldeep/OpenFOAM/kuldeep-6/run/symmetric/constant/polyMesh/boundary found on line 39 the punctuation token ')' expected either } or EOF --> FOAM FATAL IO ERROR: Expected a ')' or a '}' while reading PtrList, found on line 43 an error file: /home/kuldeep/OpenFOAM/kuldeep-6/run/symmetric/constant/polyMesh/boundary at line 43. From function char Foam::Istream::readEndList(const char*) in file db/IOstreams/IOstreams/Istream.C at line 155. FOAM exiting kuldeep@kuldeep-HP-15-TS-Notebook-PC:~/OpenFOAM/kuldeep-6/run/symmetric$ Last edited by pawansharma; December 4, 2018 at 16:21. |
anonymous
Rep Power: 14 ![]() |
Hi!
You have a problem in the boundary file. I think you have modified it and you made a typo. You missed a } or has an extra ) in your constant/polyMesh/boundary file. The error tells you the problem exactly: Code:
Reading /home/kuldeep/OpenFOAM/kuldeep-6/run/symmetric/constant/polyMesh/boundary found on line 39 the punctuation token ')' expected either } or EOF Code:
--> FOAM FATAL IO ERROR: Expected a ')' or a '}' while reading PtrList, found on line 43 an error file: /home/kuldeep/OpenFOAM/kuldeep-6/run/symmetric/constant/polyMesh/boundary at line 43. So check line 39, and 43. |
Samuele Z
Rep Power: 18 ![]() |
If you attach the file, it would be easier to help you.
Samuele |
Pawan Sharma
Problem has been solved thank you so much!
Setting up cyclic boundary condition | KateEisenhower | OpenFOAM Pre-Processing | 6 | January 11, 2017 17:17 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Time dependant pressure boundary condition | yosuke1984 | OpenFOAM Verification & Validation | 3 | May 6, 2015 06:16 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
Setting outlet Pressure boundary condition using CAFFA code | Mukund Pondkule | Main CFD Forum | 0 | March 16, 2011 03:23 |
