K-Omefa SST DES in OpenFOAM
Old   December 4, 2018, 00:39
Question K-Omefa SST DES in OpenFOAM
Sai Guruprasad Jakkala
saiguruprasad is on a distinguished road
I am trying to validate the turbulence models in OpenFOAM as a part of my research work. I was able to successfully run incompressible Spalart Allmaras DES and DDES with pisofoam.
I able to run K-Omega SST DES model also, but the results don't seem to be correct. I am validating the models using Couette Flow with Re_tau=8600. I start the simulation with the perturbUChannel as initial condition to sustain turbulence in the flow.
The results in the SA-DES show an instantaneous and mean velocity profile which are different, but in the case of k-omega SST DES the instantaneous profile coincides with the mean profile after some iterations. This leads to the wrong calculation of the Reynolds Stresses.
I would like to know what I am doing wrong with the K-Omega SST DES model?
saiguruprasad is offline   Reply With Quote
des turbulence model, k omega sst, openfoam 5.x, turbulence modelling
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology wyldckat OpenFOAM 17 November 10, 2017 16:54
Implementation of the technique DES in OpenFOAM for flow channels Ferdinand OpenFOAM Programming & Development 0 June 27, 2015 22:00
How to use DES well? Daniel Main CFD Forum 0 October 26, 2008 06:59
DES ( SA+LES) vs DES ( kwSST+LES) for bluff body Phil Main CFD Forum 0 January 8, 2008 10:04
SST based DES K.S. Chang Main CFD Forum 0 August 17, 2004 17:37
