drag value not stable even within small geometry changes |
November 26, 2018, 10:04 |
Rep Power: 8 |
I'm trying to perform calculations on set of axisimmetric geometries which differ only by definition of foci points of ellipse. Foci y dimension is in range -0.25m to 0.15m with step 0.001m so there are 401 cases. Pictures for -0.25, 0 and 0.15 are in attachments. Regardless using small step differences between geometries and different case settings - diffs between neighbor geometries are quite big and unstable (see graph in attachments). What I tried so far:
Enclosed zip with case and gmsh file. |
November 26, 2018, 18:42 |
Peter Baskovich
Rep Power: 12 |
Can you show your mesh and a checkMesh report?
November 26, 2018, 19:02 |
Rep Power: 8 |
@pete20r2 thanks for your reply
Enclosed pictures of the mesh. I was trying to make mesh with quadrilateral elements - unfortunately quad mesh is unavailable in gmsh when boundary of area is not regular. Current mesh meshCheck: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 4.0 Exec : checkMesh Date : Nov 26 2018 Time : 23:48:38 Host : "PC" PID : 3236 Case : /home/krzy/Desktop/ost/proba_21/case nProcs : 1 fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 145430 internal points: 0 faces: 486872 internal faces: 203377 cells: 138066 faces per cell: 4.99941 boundary patches: 7 point zones: 0 face zones: 0 cell zones: 1 Overall number of cells of each type: hexahedra: 0 prisms: 137891 wedges: 0 pyramids: 94 tet wedges: 0 tetrahedra: 81 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology wedge0 138066 72756 ok (non-closed singly connected) front 2710 5421 ok (non-closed singly connected) inlet 11 23 ok (non-closed singly connected) wedge1 138066 72756 ok (non-closed singly connected) back 4577 9156 ok (non-closed singly connected) outlet 42 86 ok (non-closed singly connected) tunnel 23 48 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-3.25 0 -0.0981436) (2.5 2.24786 0.0981436) Mesh has 2 geometric (non-empty/wedge) directions (1 1 0) Mesh has 3 solution (non-empty) directions (1 1 1) Wedge wedge0 with angle 2.5 degrees Wedge wedge1 with angle 2.5 degrees All edges aligned with or perpendicular to non-empty directions. Boundary openness (-4.66596e-19 7.00356e-16 -9.34168e-16) OK. Max cell openness = 3.16784e-16 OK. Max aspect ratio = 3.22455 OK. Minimum face area = 8.85554e-09. Maximum face area = 0.0588718. Face area magnitudes OK. Min volume = 1.59329e-12. Max volume = 0.00602443. Total volume = 1.2402. Cell volumes OK. Mesh non-orthogonality Max: 33.888 average: 7.3683 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.559861 OK. Coupled point location match (average 0) OK. Mesh OK. End Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 4.0 Exec : checkMesh Date : Nov 26 2018 Time : 23:50:18 Host : "PC" PID : 3273 Case : /home/krzy/Desktop/ost/proba_20_run/case nProcs : 1 fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 88141 internal points: 0 faces: 295069 internal faces: 123250 cells: 83679 faces per cell: 4.99909 boundary patches: 7 point zones: 0 face zones: 0 cell zones: 1 Overall number of cells of each type: hexahedra: 0 prisms: 83511 wedges: 0 pyramids: 92 tet wedges: 0 tetrahedra: 76 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology wedge0 83679 44109 ok (non-closed singly connected) front 1615 3231 ok (non-closed singly connected) inlet 11 23 ok (non-closed singly connected) wedge1 83679 44109 ok (non-closed singly connected) back 2773 5548 ok (non-closed singly connected) outlet 39 80 ok (non-closed singly connected) tunnel 23 48 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-3.25 0 -0.0981436) (2.5 2.24786 0.0981436) Mesh has 2 geometric (non-empty/wedge) directions (1 1 0) Mesh has 3 solution (non-empty) directions (1 1 1) Wedge wedge0 with angle 2.5 degrees Wedge wedge1 with angle 2.5 degrees All edges aligned with or perpendicular to non-empty directions. Boundary openness (-1.84021e-18 -8.1401e-16 -2.90374e-15) OK. Max cell openness = 2.87837e-16 OK. Max aspect ratio = 3.0378 OK. Minimum face area = 1.90437e-08. Maximum face area = 0.0569313. Face area magnitudes OK. Min volume = 5.14846e-12. Max volume = 0.00637896. Total volume = 1.2402. Cell volumes OK. Mesh non-orthogonality Max: 34.55 average: 7.4025 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.560643 OK. Coupled point location match (average 0) OK. Mesh OK. End |
November 26, 2018, 20:08 |
Peter Baskovich
Rep Power: 12 |
Aw man, you really don't want tets in the near wall region. Especially in low Re turbulence models. I'd recommend you remesh to using quads, you'll need to break your region down into more zones and mesh them separately. If you can mesh with a program that can generate a quad boundary layer that would be way better, you can use polyDualMesh to convert tets to poly if they are Delaunay but only for far field mesh, not wall bounded.
November 27, 2018, 10:07 |
Rep Power: 8 |
Ok, so I will try to create hex mesh by using SnappyHexMesh.
Calculation of lift and drag coefficients on airfoil | CoolHersheys | OpenFOAM Post-Processing | 5 | September 27, 2021 07:04 |
Unrealistic value for drag coefficient | tw463 | Main CFD Forum | 13 | May 10, 2020 16:59 |
[ICEM] O-grid around wing geometry | Anorky | ANSYS Meshing & Geometry | 15 | November 27, 2017 14:43 |
Drag coefficient_cylinder | B.Stas | FloEFD, FloWorks & FloTHERM | 1 | August 26, 2014 08:27 |
CFD analysis of geometry with very small inlets | tarkesdora | Main CFD Forum | 4 | July 2, 2014 14:48 |
