ssa
Rep Power: 7 ![]() |
Hi all,
I am doing a flow inside a room (x=0.8m length, z=0.4m height, y=0.4m width) with an inlet velocity of 0.225 m/s coming inside the domain through a small window like opening from the top. The simulation was done in LES - dynamickEqn. I did velocity probe at different points along the length of domain and found that there is a very little change in the velocity. See attached figure. Any idea why it happens..? I have tested it with different boundary conditions and different schemes, but the results remain the same. Thanks..! |
Robert
Rep Power: 12 ![]() |
I guess you are looking for turbulences in your flow. Is it possible that 30s is not enough to devellop the flow and as such you dont see velocity fluctuations?
If you liked my answer to your question, please consider leaving a "Like" in return ![]() |
ssa
Hi Robert,
The simulation is lagrangian. So after sometime particles are inserted and I have done the simulation for 1800 seconds. There is no change in the velocity probe after 30 seconds. That is the problem. It is not fluctuating and not reducing throughout the length of the domain. Thanks. ssa |
VELOCITY vs VELOCITY IN STN FRAME vs RELATIVE VELOCITY | everest20 | FLUENT | 1 | July 13, 2015 08:35 |
Velocity curve in channel flow by pisoFoam and LES | mxylondon | OpenFOAM Verification & Validation | 9 | June 21, 2015 07:28 |
How to define a fixed velocity for a given mass flow rate on inlet | mqasimali | FLUENT | 2 | April 12, 2013 17:24 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 02:13 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
