The problem when i use parallel computation for mesh deforming. |
November 20, 2018, 02:58 |
Hiroaki Sumikawa
Rep Power: 8 |
Hello, every one.
I want do parallel computation in mesh deforming. I could do it in rigid body movement. So, I think it is possible to use parallel computation in mesh deforming. But I have the following error. Create time Create mesh for time = 0 Selecting dynamicFvMesh dynamicMotionSolverFvMesh Selecting motion solver: velocityLaplacian [0] [0] [0] --> FOAM FATAL IO ERROR: [0] size 65709 is not equal to the given value of 1128 [0] [0] file: /home/user/user/OpenFAOM-4.1/maguro2_parallel/processor0/0/pointMotionU.boundaryField.same from line 43 to line 54. [0] [0] From function Foam::Field<Type>::Field(const Foam::word&, const Foam::dictionary&, Foam::label) [with Type = Foam::Vector<double>; Foam::label = int] [0] in file /home/user/OpenFOAM4.1/OpenFOAM-4.1/src/OpenFOAM/lnInclude/Field.C at line 295. [0] FOAM parallel run exiting [0] [2] [2] [2] --> FOAM FATAL IO ERROR: [2] size 65709 is not equal to the given value of 122 [2] [2] file: /home/user/user/OpenFAOM-4.1/maguro2_parallel/processor2/0/pointMotionU.boundaryField.same from line 43 to line 54. [2] [2] From function Foam::Field<Type>::Field(const Foam::word&, const Foam::dictionary&, Foam::label) [with Type = Foam::Vector<double>; Foam::label = int] [2] in file /home/user/OpenFOAM4.1/OpenFOAM-4.1/src/OpenFOAM/lnInclude/Field.C at line 295. [2] FOAM parallel run exiting [2] [6] [6] [6] --> FOAM FATAL IO ERROR: [6] size 65709 is not equal to the given value of 516 [6] [6] file: /home/user/user/OpenFAOM-4.1/maguro2_parallel/processor6/0/pointMotionU.boundaryField.same from line 43 to line 54. [6] [6] From function Foam::Field<Type>::Field(const Foam::word&, const Foam::dictionary&, Foam::label) [with Type = Foam::Vector<double>; Foam::label = int] [6] in file /home/user/OpenFOAM4.1/OpenFOAM-4.1/src/OpenFOAM/lnInclude/Field.C at line 295. [6] FOAM parallel run exiting [6] [8] [8] [8] --> FOAM FATAL IO ERROR: [8] size 65709 is not equal to the given value of 252 [8] [8] file: /home/user/user/OpenFAOM-4.1/maguro2_parallel/processor8/0/pointMotionU.boundaryField.same from line 43 to line 54. [8] [8] From function Foam::Field<Type>::Field(const Foam::word&, const Foam::dictionary&, Foam::label) [with Type = Foam::Vector<double>; Foam::label = int] [8] in file /home/user/OpenFOAM4.1/OpenFOAM-4.1/src/OpenFOAM/lnInclude/Field.C at line 295. [8] FOAM parallel run exiting [8] -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- [5] [5] [5] --> FOAM FATAL IO ERROR: [5] size 65709 is not equal to the given value of 4934 [5] [5] file: /home/user/user/OpenFAOM-4.1/maguro2_parallel/processor5/0/pointMotionU.boundaryField.same from line 43 to line 54. [5] [5] From function Foam::Field<Type>::Field(const Foam::word&, const Foam::dictionary&, Foam::label) [with Type = Foam::Vector<double>; Foam::label = int] [5] in file /home/user/OpenFOAM4.1/OpenFOAM-4.1/src/OpenFOAM/lnInclude/Field.C at line 295. [5] FOAM parallel run exiting [5] [1] [1] [1] --> FOAM FATAL IO ERROR: [1] size 65709 is not equal to the given value of 7133 [1] [1] file: /home/user/user/OpenFAOM-4.1/maguro2_parallel/processor1/0/pointMotionU.boundaryField.same from line 45 to line 56. [1] [1] From function Foam::Field<Type>::Field(const Foam::word&, const Foam::dictionary&, Foam::label) [with Type = Foam::Vector<double>; Foam::label = int] [1] in file /home/user/OpenFOAM4.1/OpenFOAM-4.1/src/OpenFOAM/lnInclude/Field.C at line 295. [1] FOAM parallel run exiting [1] [7] [7] [7] --> FOAM FATAL IO ERROR: [7] size 65709 is not equal to the given value of 6632 [7] [7] file: /home/user/user/OpenFAOM-4.1/maguro2_parallel/processor7/0/pointMotionU.boundaryField.same from line 45 to line 56. [7] [7] From function Foam::Field<Type>::Field(const Foam::word&, const Foam::dictionary&, Foam::label) [with Type = Foam::Vector<double>; Foam::label = int] [7] in file /home/user/OpenFOAM4.1/OpenFOAM-4.1/src/OpenFOAM/lnInclude/Field.C at line 295. [7] FOAM parallel run exiting [7] [3] [3] [3] --> FOAM FATAL IO ERROR: [3] size 65709 is not equal to the given value of 14161 [3] [3] file: /home/user/user/OpenFAOM-4.1/maguro2_parallel/processor3/0/pointMotionU.boundaryField.same from line 43 to line 54. [3] [3] From function Foam::Field<Type>::Field(const Foam::word&, const Foam::dictionary&, Foam::label) [with Type = Foam::Vector<double>; Foam::label = int] [3] in file /home/user/OpenFOAM4.1/OpenFOAM-4.1/src/OpenFOAM/lnInclude/Field.C at line 295. [3] FOAM parallel run exiting [3] [4] [4] [4] --> FOAM FATAL IO ERROR: [4] size 65709 is not equal to the given value of 31946 [4] [4] file: /home/user/user/OpenFAOM-4.1/maguro2_parallel/processor4/0/pointMotionU.boundaryField.same from line 45 to line 56. [4] [4] From function Foam::Field<Type>::Field(const Foam::word&, const Foam::dictionary&, Foam::label) [with Type = Foam::Vector<double>; Foam::label = int] [4] in file /home/user/OpenFOAM4.1/OpenFOAM-4.1/src/OpenFOAM/lnInclude/Field.C at line 295. [4] FOAM parallel run exiting [4] [user-X299-S01:11108] 8 more processes have sent help message help-mpi-api.txt / mpi-abort [user-X299-S01:11108] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages I use snappyHexMesh and pimpleDyMFoam in OpenFOAM4.1. Is it possible to use parallel computation for mesh deforming? How do you do it? If someone have any opinion or advice, I would like you tell me. Thank you. |
Problem with foam-extend 4.0 ggi parallel run | Metikurke | OpenFOAM Running, Solving & CFD | 1 | December 6, 2018 15:51 |
SU2 Parallel Computation problem | Gramanzini | SU2 | 5 | September 29, 2018 12:32 |
problem sampling a plane in parallel | syavash | OpenFOAM Post-Processing | 0 | May 7, 2018 10:15 |
Strange post processing resuls for parallel computation of Onera M6 tutorial | Akash C | SU2 Shape Design | 9 | August 30, 2013 06:05 |
Deforming wall problem | alxasli | FLUENT | 3 | January 10, 2011 06:22 |
