November 9, 2018, 18:59 |
Solving turbulence in a room
Rep Power: 11 |
Hi everyone,
I'm modelling the air flow in a room. I successfully modelled the flow using simpleFoam without turbulence but when turning turbulence on, the solver diverges. The turbulence fields are diverging starting at the edges between inlet/outlet and the air duct (wall). So I thought it is a stl problem according to the following post : https://www.cfd-online.com/Forums/op...sh-salome.html I tried different methods to optimise my mesh. For example, I used the tool surfaceMeshTriangulate to generate a waterproof mesh. The solver still diverges almost immediately. So I'm muddled. Are the boundary conditions right configured ? Is there a problem in the settings of fvSchemes and fvSolution ? Could any experienced user of snappyHexMesh and openFoam have a look and give my some hints please ? Is there a problem in the mesh generation ? In the stl files ? BCs ? Solvers settings ? You can obtain my case following this link (8Mo) : https://we.tl/t-KT2wBkQ89d After downloading and extracting, just copy, paste and run : ./Allclean && cp -r 0.orig/ 0 && blockMesh | tee log.blockMesh && surfaceFeatureExtract | tee log.surfaceFeatureExtract && snappyHexMesh -overwrite | tee log.snappyHexMesh && checkMesh | tee log.checkMesh && potentialFoam | tee log.potentialFoam && simpleFoam | tee log.simpleFoam && simpleFoam -postProcess -func yPlus | tee log.simpleFoamYPlusRAS Have a nice weekend all ! jipai Last edited by jipai; November 11, 2018 at 10:17. |
November 25, 2018, 18:35 |
Rep Power: 11 |
November 25, 2018, 21:23 |
abdikerim kurbanaliev
Rep Power: 16 |
Thanks a lot!
November 26, 2018, 06:16 |
ssa
Rep Power: 8 |
Hi, I am also doing a airflow in room. Could you upload case file in google drive or github. I couldn't open the link.
or just post your files here..! Thanks, ssa. |
November 26, 2018, 10:54 |
Rep Power: 11 |
Hi ssa,
I shared the files on google drive. Please try this link : https://drive.google.com/file/d/1c_l...ew?usp=sharing The files takes 8Mo so cfd-online doesn't accept it Have a nice day jipai |
November 26, 2018, 11:24 |
ssa
Rep Power: 8 |
I just saw your files and here is the quick review.
You are using nutKwallfunction for k. use kqrwallfunction. use wall function for nut. From my opinion, try to use pimplefoam or pisofoam with RANS. If you are running RANS, use upwind scheme for k,epsilon and omega. Don't use limitedlinear. If upwind works well, then change to linearupwind or other schemes. |
November 26, 2018, 17:51 |
Rep Power: 11 |
OK for kqRWallFunction
You're right about upwind scheme. It converges much better than limitedLinear (I actually manage to make the case converge with limitedLinear but with relaxation factors lowered to 0.5) I will try to run with pimpleFoam or pisoFoam. I'm not yet familiar with transient similations with OpenFoam, but let's give it a try ^^ Many thanks for your hints Regards jipai |
meshing ; solver settings |
conjugate heat transfer in OpenFOAM | skuznet | OpenFOAM Running, Solving & CFD | 99 | March 16, 2017 06:07 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 19:17 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 07:37 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 13:50 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
