simplifiedSiwek - error in calculating the position of a coal error
Old   November 4, 2018, 05:06
Default simplifiedSiwek - error in calculating the position of a coal error
Boday
guitar_love_15 is on a distinguished road
Hi, everyone.
I have problems, when I try to place coal dust in the inside of my body. I created a geometric body in SALOME.
Its options (Parallelepiped):
x = 0.2m, number of coordinates 20;
y = 0.2m, coordinate number 20;
z = 1m, number of coordinates 20;
In the area of x and y i can arrange locate 6 coordinates. If more (10,18 coordinates) then I get an error:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  6
     \\/     M anipulation  |
Build  : 6-1a0c91b3baa8
Exec   : coalChemistryFoam
Date   : Nov 04 2018
Time   : 10:33:17
Host   : "bogdan"
PID    : 2409
I/O    : uncollated
Case   : /home/bogdan/Desktop/try/simplifiedSiwek_1
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
PIMPLE: No convergence criteria found
PIMPLE: Operating solver in PISO mode
Reading g
Reading thermophysical properties
Selecting thermodynamics package
    type            hePsiThermo;
    mixture         reactingMixture;
    transport       sutherland;
    thermo          janaf;
    energy          sensibleEnthalpy;
    equationOfState perfectGas;
    specie          specie;
Selecting chemistryReader foamChemistryReader
    elements not defined in "/home/bogdan/Desktop/try/simplifiedSiwek_1/constant/foam.inp"
Creating component thermo properties:
    multi-component carrier - 6 species
    liquids - 1 components
    solids - 2 components
Reading field U
Creating turbulence model
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
RAS
    RASModel        kEpsilon;
    turbulence      on;
    printCoeffs     yes;
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    C3              0;
    sigmak          1;
    sigmaEps        1.3;
Creating combustion model
Selecting combustion model PaSR
Selecting chemistry solver
    solver          ode;
    method          standard;
StandardChemistryModel: Number of species = 6 and reactions = 2
Selecting ODE solver seulex
    using integrated reaction rate
Creating field dpdt
Creating field kinetic energy K
No MRF models present
Constructing coal cloud
Constructing particle forces
    Selecting particle force sphereDrag
    Selecting particle force gravity
Constructing cloud functions
    none
Constructing particle injection models
Creating injector: model1
Selecting injection model manualInjection
    Constructing 3-D injection
Selecting distribution model RosinRammler
Selecting dispersion model stochasticDispersionRAS
Selecting patch interaction model standardWallInteraction
Selecting stochastic collision model none
Selecting surface film model none
Selecting U integration scheme Euler
Selecting heat transfer model RanzMarshall
Selecting T integration scheme analytical
Selecting composition model singleMixtureFraction
Selecting phase change model liquidEvaporation
Participating liquid species:
    H2O
Selecting devolatilisation model constantRateDevolatilisation
Participating volatile species:
    CH4: particle mass fraction = 0.127444
    H2: particle mass fraction = 0.020889
    CO2: particle mass fraction = 0.062667
Selecting surface reaction model COxidationKineticDiffusionLimitedRate
    C(s): particle mass fraction = 0.659000048
Constructing limestone cloud
    none
Selecting radiationModel P1
Selecting absorptionEmissionModel binaryAbsorptionEmission
Selecting absorptionEmissionModel constantAbsorptionEmission
Selecting absorptionEmissionModel cloudAbsorptionEmission
Selecting scatterModel cloudScatter
Creating finite volume options from "constant/fvOptions"
Selecting finite volume options model type fixedTemperatureConstraint
    Source: source1
    - selecting cells using cellSet ignitionCells
    - selected 1 cell(s) with volume 5e-06
Courant Number mean: 0 max: 0
Starting time loop
deltaT = 0.000119047619
Time = 0.000119048
Solving 3-D cloud coalCloud1
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigSegv::sigHandler(int) at ??:?
#2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::particle::trackToStationaryTri(Foam::Vector<double> const&, double, int&) at ??:?
#4  Foam::particle::trackToFace(Foam::Vector<double> const&, double) at ??:?
#5  Foam::particle::track(Foam::Vector<double> const&, double) at ??:?
#6  Foam::particle::locate(Foam::Vector<double> const&, Foam::Vector<double> const*, int, bool, Foam::string) at ??:?
#7  Foam::particle::particle(Foam::polyMesh const&, Foam::Vector<double> const&, int) at ??:?
#8  Foam::ReactingMultiphaseParcel<Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > > >::ReactingMultiphaseParcel(Foam::polyMesh const&, Foam::Vector<double> const&, int) at ??:?
#9  void Foam::InjectionModel<Foam::KinematicCloud<Foam::Cloud<Foam::ReactingMultiphaseParcel<Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > > > > > >::inject<Foam::ReactingMultiphaseCloud<Foam::ReactingCloud<Foam::ThermoCloud<Foam::KinematicCloud<Foam::Cloud<Foam::ReactingMultiphaseParcel<Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > > > > > > > > >(Foam::ReactingMultiphaseCloud<Foam::ReactingCloud<Foam::ThermoCloud<Foam::KinematicCloud<Foam::Cloud<Foam::ReactingMultiphaseParcel<Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > > > > > > > >&, Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > >::trackingData&) at ??:?
#10  void Foam::KinematicCloud<Foam::Cloud<Foam::ReactingMultiphaseParcel<Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > > > > >::evolveCloud<Foam::ReactingMultiphaseCloud<Foam::ReactingCloud<Foam::ThermoCloud<Foam::KinematicCloud<Foam::Cloud<Foam::ReactingMultiphaseParcel<Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > > > > > > > > >(Foam::ReactingMultiphaseCloud<Foam::ReactingCloud<Foam::ThermoCloud<Foam::KinematicCloud<Foam::Cloud<Foam::ReactingMultiphaseParcel<Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > > > > > > > >&, Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > >::trackingData&) at ??:?
#11  void Foam::KinematicCloud<Foam::Cloud<Foam::ReactingMultiphaseParcel<Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > > > > >::solve<Foam::ReactingMultiphaseCloud<Foam::ReactingCloud<Foam::ThermoCloud<Foam::KinematicCloud<Foam::Cloud<Foam::ReactingMultiphaseParcel<Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > > > > > > > > >(Foam::ReactingMultiphaseCloud<Foam::ReactingCloud<Foam::ThermoCloud<Foam::KinematicCloud<Foam::Cloud<Foam::ReactingMultiphaseParcel<Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > > > > > > > >&, Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > >::trackingData&) at ??:?
#12  Foam::ReactingMultiphaseCloud<Foam::ReactingCloud<Foam::ThermoCloud<Foam::KinematicCloud<Foam::Cloud<Foam::ReactingMultiphaseParcel<Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > > > > > > > >::evolve() at ??:?
#13  ? at ??:?
#14  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#15  ? at ??:?
Segmentation fault (core dumped)
How to solve this problem?
Please help me.
My model is here. To start, you need to write in the terminal ./Allrun
https://ru.files.fm/u/yp6b5wgv
guitar_love_15 is offline   Reply With Quote
coalchemistryfoam, openfoam, particle
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 08:11
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
