Lift and Drag prediction of an airfoil at a very low Reynolds number |
November 3, 2018, 00:55 |
Subham
Rep Power: 8 |
I am trying to perform the simulation of a NACA0012 airfoil at a very low Reynolds number. The lift and drag coefficient matches exactly with the experimental data up to 5 degrees. However, for an Angle of Attack of 10 degrees and above, the simulation is over-predicting the lift coefficient. The drag coefficient is however within the error bars. One of the reasons might be the transition from laminar to the turbulent regime and successive reattachment, which gives rise to bubble separation and hence alters the lift and drag coefficient. How can I solve this problem?
Calculation of lift and drag coefficients on airfoil | CoolHersheys | OpenFOAM Post-Processing | 5 | September 27, 2021 06:04 |
wrong SU2 calculation for lift and drag coefficient for NAC4421 | mechy | SU2 | 7 | January 9, 2017 05:18 |
High drag for airfoil compared to XFOIL and wind tunnel data | Ry10 | SU2 | 15 | October 30, 2016 17:27 |
Lift and drag coefficients for low reynolds numbers typical of VAWT | akku | CFX | 2 | December 17, 2013 06:40 |
Simulation of 0021 airfoil at 120,000 Reynolds number | AUCH | FLUENT | 0 | September 24, 2013 23:05 |
