November 1, 2018, 22:25 |
CFD-PBE simulations for multi-phase systems
#1 | |
Dongyue Li
Rep Power: 18 |
Dear OpenFOAM colleagues,
I am glad to share our work on the "CFD-PBE simulations for the liquid-liquid dispersions by OpenFOAM" with you. In this paper, we couple the EQMOM algorithm with the two fluid model (TFM, twoPhaseEulerFoam), to simulate liquid-liquid dispersions in stirred tanks. Multi-fractal breakage and coalescence and other kernels are implemented. Our simulation results agree well with the experimental data. I hope this work might shed some lights on similar investigations. https://onlinelibrary.wiley.com/doi/...1002/aic.15557 Bonus: we are working on new solvers based on OpenFOAM, in which the disperse phase was solved purely by the generalized population balance equation (GPBE). It implies the N-S equations for the disperse phase can be completely discarded. We verify the code with experiments for bubbly plumes in bubble columns, and poly-disperse bubbly flows in vertical pipes (wall peak and double peak phenomenon). Good results were obtained. The solver will be open-sourced ASAP after the manuscript is accepted. Quote:
Best, Dongyue
My OpenFOAM algorithm website: http://dyfluid.com By far the largest Chinese CFD-based forum: http://www.cfd-china.com/category/6/openfoam We provide lots of clusters to Chinese customers, and we are considering to do business overseas: http://dyfluid.com/DMCmodel.html |
January 10, 2019, 04:02 |
Dongyue Li
Rep Power: 18 |
I also suggest our other work published in 2018, in which the quadrature-based moment methods for the population balance equation is fully reviewed. After these years implementing work in OpenFOAM. I do learn alot on the numerics.. But never too old to learn.
See it here: Quadrature-based moment methods for the population balance equation: An algorithm review https://www.sciencedirect.com/scienc...04954118304087 Best, Dongyue
[swak4Foam] mass conservation of solid phase violated when using groovyBC with twoPhaseEulerFoam | xpqiu | OpenFOAM Community Contributions | 8 | June 17, 2015 03:08 |
EngD in CFD Optimisation of Wastewater Treatment Systems | grtabor | OpenFOAM Announcements from Other Sources | 0 | July 12, 2012 09:55 |
Hardware specifications for CFD simulations! | parisa- | Hardware | 7 | October 24, 2011 23:57 |
ASME CFD Symposium - Call for Papers | Chris R. Kleijn | Main CFD Forum | 0 | September 8, 1998 09:19 |
ASME CFD Symposium - Call for Papers | Chris R. Kleijn | Main CFD Forum | 0 | September 3, 1998 09:45 |
