Mesh problem
Old   October 31, 2018, 10:19
Exclamation Mesh problem
Boday
guitar_love_15 is on a distinguished road
Hi!!!
I created a Mesh in Salome and imported it into OpenFoam.
After changing some of the parameters in the directory where the model files are located.
I run a compilation of my project, but I got an error:
--> FOAM Warning :
    From function Foam::scalar Foam::janafThermo<EquationOfState>::limit(Foam::scalar) const [with EquationOfState = Foam::perfectGas<Foam::specie>; Foam::scalar = double]
    in file /home/ubuntu/OpenFOAM/OpenFOAM-6/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 117
    attempt to use janafThermo<EquationOfState> out of temperature range 0 -> 5000;  T = -2508.182722
--> FOAM Warning :
    attempt to use janafThermo<EquationOfState> out of temperature range 0 -> 5000;  T = -2631.309992
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::hePsiThermo<Foam::psiReactionThermo, Foam::SpecieMixture<Foam::reactingMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > > >::calculate() at ??:?
#4  Foam::hePsiThermo<Foam::psiReactionThermo, Foam::SpecieMixture<Foam::reactingMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > > >::correct() at ??:?
#5  ? at ??:?
#6  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#7  ? at ??:?
Floating point exception (core dumped)
I can not understand why this happened?
simplifiedSiwek.zip
guitar_love_15 is offline   Reply With Quote
Old   November 5, 2018, 04:12
Robert
RobertHB is on a distinguished road
Originally Posted by guitar_love_15 View Post
Did you check your temperature boundary conditions?
If you liked my answer to your question, please consider leaving a "Like" in return
RobertHB is offline   Reply With Quote
Old   November 5, 2018, 07:11
Peter Baskovich
pete20r2 is on a distinguished road
You probably want to run a temperature limiter while you get the run started.
https://www.openfoam.com/documentati...8H_source.html
You can also find how to automatically turn the limiter off after a certain time to be sure it's not causing false results later.
pete20r2 is offline   Reply With Quote
Old   May 13, 2019, 12:00
charles4allme is on a distinguished road
RobertHB have you been able to figure it out. i have the same problem
charles4allme is offline   Reply With Quote
mesh, openfaom
Dynamic Mesh Problem. Tom Clark FLUENT 10 June 21, 2021 05:27
[snappyHexMesh] SHM problem : KVLCC2 with appendage mesh sc.park OpenFOAM Meshing & Mesh Conversion 1 March 13, 2016 14:28
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
[ICEM] ICEM Structured Mesh Problem OMJT ANSYS Meshing & Geometry 3 March 22, 2013 11:06
[GAMBIT] SOFC crossflow mesh possible problem??? epc1 ANSYS Meshing & Geometry 1 February 4, 2013 02:57
