A. Min
Rep Power: 12 ![]() |
Hi all
I simulate transient incompressible creep flow on a couple of cylinders to calculate drag force in a special period of time. The drag coeff. oscillates with time (figure) and I don't know why! Re=1, dt=0.005(Cr=0.8), SIMPLE algorithm, tolerances are set on 1e-12, URFs=0.5, 2nd order schemes are used for divergence terms and time derivative. I think it is because of Mesh, but I don't know if it is correct or not and how I should improve it. ![]() ![]() Thenks |
Peter Baskovich
Can you share the case or at least log file?
A. Min
creep, drag, numerical, openfoan, oscillation |
Keeping intermediate files | OVS | SU2 | 5 | December 5, 2021 11:41 |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
Turbulent parameters for external flow | Dorian1504 | Main CFD Forum | 0 | June 28, 2017 00:33 |
best setting for SU2 | mechy | SU2 | 3 | April 20, 2014 19:13 |
The effect of setting parameters on the roll type flow | saharesobh | FLUENT | 1 | February 9, 2013 16:49 |
