Homemade Cluster: Segmentation fault, Address not mapped |
October 30, 2018, 08:37 |
Rep Power: 8 |
I've been trying to build a small cluster as a learning experience and am a bit stuck.
> I am currently testing it out with just the host and a single node. > I decomposed a test case into 8 processor directories and placed it on both machines (they are cloned with different names) > I use the command "mpirun -x MPI_BUFFER_SIZE -n 8 --hostfile machinefile rhoPimpleFoam -parallel" I get the error: Code:
[tb1:18559] *** Process received signal *** [tb1:18559] Signal: Segmentation fault (11) [tb1:18559] Signal code: Address not mapped (1) [tb1:18559] Failing at address 0x326270 [tb1:18559] *** End of error message *** Segmentation Fault Thank you! |
November 1, 2018, 17:37 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick questions:
cluster, openfoam, openmpi |
Segmentation fault in SU2 V5.0 | ygd | SU2 | 2 | March 1, 2017 05:38 |
[OpenFOAM] Segmentation Fault on start - pvserver using o/s rendering, remote on cluster | chrisb2244 | ParaView | 2 | June 8, 2014 22:26 |
Problems installing OpenFOAM 2.3.0, 1.6-ext and foam-extend 3.0 | sam.ho | OpenFOAM Installation | 35 | April 5, 2014 16:31 |
segmentation fault when installing OF-2.1.1 on a cluster | Rebecca513 | OpenFOAM Installation | 9 | July 31, 2012 16:06 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 15:37 |
