Wrong token type - Error
Old   October 29, 2018, 08:45
Default Wrong token type - Error
Martin Rønnov Andersen
Skymaas is on a distinguished road
Hello guys,
I am currently trying to run a RAS simulation, based on the "PitzDaily" tutorial (simpleFoam), and I have no problem running the tutorial but when i add my own mesh, i get the following error:
|  \\    /   O peration     | Version:  4.0                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 4.0
Exec   : simpleFoam
Date   : Oct 29 2018
Time   : 10:32:24
Host   : "martin-7920-Tower"
PID    : 22720
Case   : /home/martin/Desktop/Project
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
SIMPLE: convergence criteria
    field p     tolerance 0.01
    field U     tolerance 0.001
    field "(k|epsilon|omega|f|v2)"     tolerance 0.001
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    C3              -0.33;
    sigmak          1;
    sigmaEps        1.3;
No MRF models present
No finite volume options present
Starting time loop
Time = 0.001
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.000131955, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 2.27221e-05, No Iterations 1
GAMG:  Solving for p, Initial residual = 1, Final residual = nan, No Iterations 1000
GAMG:  Solving for p, Initial residual = nan, Final residual = nan, No Iterations 1000
--> FOAM FATAL IO ERROR:
wrong token type - expected Scalar, found on line 0 the word 'nan'
file: /home/martin/Desktop/Project/system/data.solverPerformance.p at line 0.
    From function Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::doubleScalar&)
    in file lnInclude/Scalar.C at line 93.
FOAM exiting
I am fairly new to this, but from what i can see it seems like it has something to do with the solver for "p". I have tried to simplify the mesh(Since i am working with simpleFoam) but that didn´t do anything.
The files for running the simulation can be found here.
Skymaas is offline   Reply With Quote
expected, openfoam, scalar, token, wrong
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 08:43
Divergent temperature in chtMultiRegion(Simple)Foam akrasemann OpenFOAM Running, Solving & CFD 13 March 24, 2014 03:54
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
