October 26, 2018, 11:38 |
Air entrainment at boundary condition
Akshay Patil
Rep Power: 10 |
I am trying to model a wave over a sloping beach profile using OpenFOAM-v1806. When I use the stokesI model with rampTime ~ wave Period or 2*wavePeriod, I observe that air is drawn into the flow depth. This makes it difficult to compare the wave model with the experimental data. Is there something I am missing? I do not want the air to be entrained this way at the boundary condition.
I have tried to force water inflow using the following line of code in the 0/U boundary definition inlet { type waveAlpha; value uniform (0 0 0); alpha alpha.water; } However, this does not work. Please have a look at the image I have included. I have also included the OpenFOAM files in the waveModel.zip attachment. Any suggestions would be appreciated, thank you! |
November 28, 2018, 08:09 |
Akshay Patil
Rep Power: 10 |
In case you are struglling with the same problem, there was an inconsistent boundary condition in alpha.water for inlet. It should not be zeroGradient but waveAlpha just like the velocity boundary condition.
air, interfoam, waves |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
