solver converges in 2 iterations
Old   October 25, 2018, 19:25
Default solver converges in 2 iterations
Reviewer #2
randolph is on a distinguished road
Hi everyone,
I have experienced some weird convergence issue with the transportFoam on a hpc. The simulation converges in 2 iterations...
Time = 1
DILUPBiCGStab:  Solving for T, Initial residual = 1, Final residual = 4.5508e-09, No Iterations 6
DILUPBiCGStab:  Solving for T, Initial residual = 1.48813e-238, Final residual = 2.17278e-239, No Iterations 1
DILUPBiCGStab:  Solving for T, Initial residual = 7.32543e-239, Final residual = 1.02164e-239, No Iterations 1
Time = 2
DILUPBiCGStab:  Solving for T, Initial residual = 4.76531e-239, Final residual = 6.39731e-240, No Iterations 1
DILUPBiCGStab:  Solving for T, Initial residual = 3.49174e-239, Final residual = 4.59086e-240, No Iterations 1
DILUPBiCGStab:  Solving for T, Initial residual = 2.73492e-239, Final residual = 3.54658e-240, No Iterations 1
SIMPLE solution converged in 2 iterations
End
Finalising parallel run
But If I start another exact same run, the model will behave well.
Time = 1
DILUPBiCGStab:  Solving for T, Initial residual = 1, Final residual = 4.54546e-09, No Iterations 6
DILUPBiCGStab:  Solving for T, Initial residual = 0.102393, Final residual = 2.91777e-09, No Iterations 5
DILUPBiCGStab:  Solving for T, Initial residual = 0.0527999, Final residual = 7.78017e-09, No Iterations 5
Time = 2
DILUPBiCGStab:  Solving for T, Initial residual = 0.0350811, Final residual = 4.8293e-09, No Iterations 5
DILUPBiCGStab:  Solving for T, Initial residual = 0.0260212, Final residual = 7.77216e-09, No Iterations 4
DILUPBiCGStab:  Solving for T, Initial residual = 0.0205409, Final residual = 5.81297e-09, No Iterations 4
Has anyone experienced a similar issue? And what would be the cause? The following is my fvSolution file. I run the model with steadyState mode.
solvers
    T
        solver          PBiCGStab;
        preconditioner  DILU;
        tolerance       1e-08;
        relTol          0;
		minIter         1;
SIMPLE
    nNonOrthogonalCorrectors 0;
	consistent      yes;
    residualControl
        T               1e-8;
relaxationFactors
    equations
        T               0.5;
Any guidance will be appreciated.
Rdf
randolph is offline   Reply With Quote
Suppress twoPhaseEulerFoam energy AlmostSurelyRob OpenFOAM Running, Solving & CFD 33 September 25, 2018 18:45
pressure in incompressible solvers e.g. simpleFoam chrizzl OpenFOAM Running, Solving & CFD 13 March 28, 2017 06:49
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
should Courant number always be kept below 1? wc34071209 OpenFOAM Running, Solving & CFD 16 March 9, 2014 20:31
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 13:50
