Anybody tried modelling your own propeller and running with pimpleDyMFoam? |
October 17, 2018, 23:27 |
zhi
Rep Power: 7 |
Hi, am trying to run my own propeller simulation. Currently i am using pimpleDyMFoam, not sure whether it is the right solver to be used. As i fail to use snappyhexmesh to mesh the propeller appropriately, started meshing in Ansys fluent and importing mesh to openfoam. However, im facing some issue with setting up the case and running the solver. Some help will be appreciated!
October 19, 2018, 04:38 |
Zander Meiring
Rep Power: 7 |
Just as a slight warning; fluent can handle worse quality meshes than openfoam. Just make sure to run a 'checkMesh' and ensure at least skewness is under 4, and preferably orthogonality under 70deg.
As for your case setup; we're going to need more detail. What aspect of it are you struggling? boundary conditions? solution schemes? what reasoning do you have behind pimpleDyMFoam? |
October 19, 2018, 06:33 |
Peter Baskovich
Rep Power: 11 |
Which version of OF are you using? The mesh interfaces, mesh motion and schemes are handled a bit differently in different versions so it is important to know.
Propeller Simulations at an Angle of Attack using MRF method | wingster77 | FLUENT | 1 | April 22, 2024 05:09 |
OpenFOAM parallel on VM? pimpleDyMFoam propeller tutorial has been running for hours. | MBttR | OpenFOAM Running, Solving & CFD | 0 | June 13, 2016 10:58 |
Running propeller tutorial !! | S.E. Kwon | OpenFOAM Running, Solving & CFD | 0 | October 27, 2014 22:01 |
Running Propeller with PimpleDyMFoam | 30na | OpenFOAM Running, Solving & CFD | 1 | September 23, 2014 06:42 |
Error running Propeller Tutorial | TOM01 | OpenFOAM Running, Solving & CFD | 2 | October 16, 2013 06:44 |
