simpleFoam convergence issue
Old   October 15, 2018, 06:33
Unhappy simpleFoam convergence issue
arash
handicraft is on a distinguished road
hi all
I am trying to simulate a car in wind tuunel using simplefoam (steady-state) solver (k-omega) without turbolence and i meshing geometry with SHM. final mesh had 4.4m cell. the problem is that residuals converge at high values (0.01). i do it with 1.4m cell and residuals converge at 0.0001 . i change the scheme to high order scheme (second order accurate) but nothing change.
What is wrong in my case? and how i can improve it?
Thank you very much for your help.
controlDict.zip
fvSchemes.zip
fvSolution.zip
0.zip
handicraft is offline   Reply With Quote
Old   October 15, 2018, 10:27
Arvind Jay
arvindpj is on a distinguished road
Try reducing the relaxation factors:
relaxationFactors
   field
       p   0.8;
    equations
        U               0.2;
        k               0.5;
        omega       0.5;
arvindpj is offline   Reply With Quote
Old   October 15, 2018, 13:30
arash
Thanks for the answer,
i do this and here the residuals plot:
It's totally messed up
Old   October 15, 2018, 13:31
Arvind Jay
Could you share the full case with mesh?
Old   October 15, 2018, 13:48
arash
that means you need 0,constant,system folder? because they are huge (like 400 mbyte)
Old   October 15, 2018, 13:50
Arvind Jay
did you create the mesh using SHM or cfMesh.. then use foamCleanPolyMesh and send only the scripts.
Old   October 15, 2018, 14:02
arash
sorry I am new to OpenFoam and little confused. yes i'm using SHM, and when i use this command (foamCleanPolyMesh) nothing happend. only show "Cleaning ./constant/polyMesh"
Old   October 15, 2018, 14:17
Arvind Jay
Now the file size would be small and you could share.
Old   October 15, 2018, 14:25
arash
thanks, sorry but file still 1.4mb and forums don't let me upload here, so i uploded some were elese,
here the case:
http://www.mediafire.com/file/guewlz...3/car.zip/file
Old   October 15, 2018, 20:59
Peter Baskovich
pete20r2 is on a distinguished road
Try more cells on the ground around the car, there will be a velocity gradient under the both to the undertray and to the ground so you need a boundary layer of prism cells there too. Also try a cell size of about a quarter of what is currently under the car. For an easy test, turn on boundary cells for the whole floor patch and thicken the first refinement layer off the vehicle until it is affecting the floor around the vehicle.
pete20r2 is offline   Reply With Quote
convergance, k-omega model, residual, simplefoam, steady state
Convergence Centurion2011 FLUENT 48 June 15, 2022 00:29
Convergence issue with continuity equation Jake FLUENT 8 June 6, 2018 04:41
simpleFoam: simple 1-D channel flow, yet very strange convergence behavior kishpishar OpenFOAM Running, Solving & CFD 2 June 20, 2013 14:55
Convergence rate of SimpleFoam boddyouareboy OpenFOAM 0 January 25, 2011 04:49
SimpleFOAM + SST-Model + problem with convergence A.Devesa OpenFOAM Running, Solving & CFD 0 November 9, 2010 05:43
