Acoustic radiation force on rigid sphere
Old   October 11, 2018, 05:41
Default Acoustic radiation force on rigid sphere
Johannes Voß
J.H.59 is on a distinguished road
Hi there
I'm trying to simulate a rigid sphere in an acoustic field in water to calculate the acoustic radiation force on it and then compare the solution with the analytic one.
The simulation geometry is a sphere in a box and on one site a sinus pressure wave is entering the box. On the other sides of the box there should be non-reflecting BC's. The temperature is hold constant at 293.15K with fixedTemperatureConstraint in fvOptions.
The sphere has the radius 1mm and the size of the box is 0.1m.
My BC's are:
p:
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 101325;
boundaryField
    inlet
        type                uniformFixedValue;
        uniformValue        sine;
        uniformValueCoeffs
            t0                  0;
            amplitude           constant 100;
            frequency           constant 10000;
            scale               constant 1;
            level               constant 101325;
        value                uniform 101325;
    sphere
        type            zeroGradient;
        type           waveTransmissive;
        field          p;
        phi            phi;
        rho            rho;
        psi            thermo:psi;
        gamma          1.01;
        fieldInf       101325;
        lInf           8e-2;
U:
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type        pressureInletOutletVelocity;
        value       uniform (0 0 0);
    sphere
        type            noSlip;
        field      U;
        phi        phi;
        rho        rho;
        psi        thermo:psi;
        gamma      1.01;
        fieldInf   (0 0 0);
        lInf       8e-2;
T:
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 293.15;
boundaryField
        type            zeroGradient;
The thermophysicalProperties:
thermoType
    type            heRhoThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState perfectFluid;
    specie          specie;
    energy          sensibleInternalEnergy;
mixture
    specie
        molWeight   18.015268;
    equationOfState
        R           461.4;//in J * kg^-1 * K^-1
        rho0        996.2896401;
    thermodynamics
        Cp          4189.683866;
        Hf          333550; //J/kg
    transport
        mu          0.001;
        nu          2.87e-3;
        Pr          6.99;
So far I'm just able to run a simulation with rhoPimpleFoam. But the force is not even close to the analytic one.
Is there something wrong with my BC's, the termophysicalProperties or something else?
Thanks in advance
J.H.59 is offline   Reply With Quote
acoustic pressure, acoustic reflectivity, acoustics, rhopimplefoam
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
rigid body motions- no external force armin najarian Main CFD Forum 1 July 6, 2016 04:19
radiation flux rejected from surface sachin kumar Main CFD Forum 1 June 16, 2015 03:43
DEFINE_CG_MOTION and pressure force Teo Fumagalli FLUENT 0 April 11, 2008 11:25
How calculate drag force for porous sphere Chandan Sarkar FLUENT 2 September 23, 2002 03:12
