set a fixed value to the internal field
Old   October 6, 2018, 05:52
Default set a fixed value to the internal field
jiahui_93 is on a distinguished road
Hello, I would like to get some help on the way to set a fixed value to the internal field of nut, so that it stay constant over time step. I tried many times but it seems keep changing over time steps for both uniform and non uniform type. The "constant" keyword is not available for internal field. May I know any other way to do? Thanks for your time and help.
Jia Hui
jiahui_93 is offline   Reply With Quote
Old   October 6, 2018, 10:55
Vince
hyFoam is on a distinguished road
Hi Jia Hui,
Your question sounds similar to that of this post where someone wanted to fix the velocity vector in one cell of the domain, i.e., not to solve the momentum equation for this cell:
Fix velocity value
Please have a look.
Thanks,
Vince
hyFoam is offline   Reply With Quote
Old   October 6, 2018, 11:33
Originally Posted by hyFoam View Post
Hi Jia Hui,
Fix velocity value
Please have a look.
Thanks,
Vince
Thanks a lot for your help.
p/s: I'm using pimpleFoam to run incompressible flow within a rectangular duct with a small solid within it. I would like to fix nut internal field value.
Should I create or use other .H file in the incompressible directory? I have pEqn.H, UEqn.H, createFiels.H and pimpleFoam.c in my pimpleFoam directory.
or it can be done by edit the following file (replace the existing with the code u provide)?
https://github.com/vincentcasseau/hy...vEqnInviscid.H
After edit the file, i can run the solver? Do i need to set anything in the internal field ? Eg: uniform 1 or non uniform..?
Sorry for my dummy question, because i have totally no basic on programming, learning from zero now��. Thanks again for your help. Appreciate it
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 08:30
How to set some p.internalField to be fixed? Kelong Wang OpenFOAM Pre-Processing 0 December 4, 2014 21:39
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
correction of Grub after installing Windows XP and 8 immortality Lounge 20 January 5, 2014 18:41
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 10:53
