OF v1612+ scalarTransport
Old   October 5, 2018, 14:51
Exclamation OF v1612+ scalarTransport
B. Assaad
bassaad17 is on a distinguished road
I'm trying to get the correct Tracer file for my model properly defined in 'controlDict' but the model does NOT run in parallel when using 16 processors for OF v1612+.
The model I received was written for OF v1606+ and it is running properly when using 'mpirun -np 8 buoyantBoussinesqSimpleFoam -parallel >> buoyantBoussSimpleFoam20.log' on OFv1606+
This is the tracer definition as written in OF v1606+
SPLC_Tracer
		type scalarTransport;
		functionObjectLibs ("libutilityFunctionObjects.so");
		writeControl outputTime;
		writeInterval 8;
		active 	true;
		autoSchemes false;
		nCorr	0;
		resetOnStartUp false;
		fvOptions
When doing research online, i found out that OF v1612+ updated the functionObjectLibs to libs and this is the new code i'm using:
SPLC_Tracer
		libs ("libsolverFunctionObjects.so");
		field SPLC_Tracer;
		writeInterval 8;
		active 	true;
		autoSchemes false;
		nCorr	0;
		fvOptions
When I run the new SPLC_Tracer with OF v1612+, my model does NOT run in parallel - it crashes saying "MPI_ABORT"
This is the error seen on my linux terminal screen:
[2] --> FOAM FATAL IO ERROR:
[2] cannot find file
[2]
[2] file: /Projects/2018_10_03/RUN2_RMR/processor2/24/SPLC_Tracer at line 0.
[2]
[2]     From function regIOobject::readStream()
[2]     in file db/regIOobject/regIOobjectRead.C at line 237.
[2]
FOAM parallel run exiting
[2]
[linux-n2:13111] 15 more processes have sent help message help-mpi-api.txt / mpi-abort
[linux-n2:13111] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
Do you know what do i need to do to overcome this issue and properly run my tracer in OF v1612+? I've also attached the .log file. Please help!
Last edited by bassaad17; October 5, 2018 at 16:27. Reason: included error message
bassaad17 is offline   Reply With Quote
Old   October 8, 2018, 09:05
Robert
RobertHB is on a distinguished road
Originally Posted by bassaad17 View Post
SPLC_Tracer
        field SPLC_Tracer;
        writeInterval 8;
        active     true;
        autoSchemes false;
        nCorr    0;
        fvOptions
[2]
[2]
[2]
[2]
The field you defined in your code snippet is a dictionary file containing the boundary conditions for your tracer and which has to be placed in the 0/ folder. By standard this file is called T or s, but you told your simulation the file is called SPLC_Tracer. So make sure that this file is accurately named and placed in the 0/ folder. Obviously this file has also to appear in all following timestep folder (e.g. 24).
If you liked my answer to your question, please consider leaving a "Like" in return
RobertHB is offline   Reply With Quote
controldict, openfoam, tracer, v1606+, v1612+
interFoam and scalarTransport function object with fvOptions sources fusij OpenFOAM Running, Solving & CFD 4 April 18, 2022 08:12
functionObject scalarTransport searches File s fanta OpenFOAM Running, Solving & CFD 0 September 4, 2017 04:01
scalarTransport pez OpenFOAM Post-Processing 5 March 29, 2016 11:49
fvOptions scalarTransport utility matthew.legg OpenFOAM Post-Processing 16 April 14, 2015 13:23
Regarding the adaptation of scalarTransport Foam as well as general openFOAM logic. HFonten1 OpenFOAM 0 August 10, 2010 14:05
