hpc multi-node parallel error
Old   October 4, 2018, 22:09
Default hpc multi-node parallel error
XIANGYU SHI
shixiangyu is on a distinguished road
hi guys i have a problem when i used mpirun --hostfile ~~~
i posted some pics like this
the error always shows“” All nodes which are allocated for this job are already filled.” but it shows %CPU is 0 !! with “top” command at each node
i tried so many method about mpirun command:
mpirun --hostfile machines -np 20 interFoam -parallel
foamJob -p interFoam
And the HPC cluster have 3 nodes , i also found the “”/etc/hosts“” file
like this
127.0.0.1 localhost.localdomain localhost
203.234.54.110 naoe02-PC
10.0.1.254 anode0.kunsan.ac.kr anode0 a0 node0 cw0
10.0.1.1 anode1.kunsan.ac.kr anode1 a1 node1
10.0.1.2 anode2.kunsan.ac.kr anode2 a2 node2
anyone solved this problem help me plz
shixiangyu is offline   Reply With Quote
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 14:21
[OpenFOAM] an error in Calculator's equation immortality ParaView 12 June 29, 2021 01:10
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
