Problem using turbulent modelling with rhoCentralFoam in foam extend 4.0 |
TWB
Rep Power: 19 ![]() |
I am trying to run a hypersonic flow simulation using turbulent modelling (k-omega sst) with rhoCentralFoam in foam extend 4.0. I managed to run successfully with dbnsTurbFoam but when I run with rhoCentralFoam, it runs but it seems to be running in laminar mode. There is no calculation of turbulent variables like omega etc. Why is this so? Is this supposed to be the case? I have shown the case files: FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object turbulenceProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // simulationType RASModel; FoamFile { version 2.0; format ascii; class dictionary; object RASProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // RASModel kOmegaSST; turbulence on; printCoeffs on; |
Sakun
Rep Power: 6 ![]() |
I know this is an old thread but did you manage to succeed ? ![]() I have similar problem like you. |
[foam-extend.org] A problem about installation of open foam extend 3.1 | Toalchemist | OpenFOAM Installation | 1 | May 31, 2018 08:58 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 04:38 |
