--> FOAM FATAL ERROR: invalid path specification
Old   October 2, 2018, 10:22
Default --> FOAM FATAL ERROR: invalid path specification
Przemek
gaza is on a distinguished road
Hi All,
I am using OF v1612 and previous calculations were stopped by the solver during
the write at 100 s:
Time = 100
Courant Number mean: 0.00949898 max: 0.0999998
deltaT = 0.00030688
PIMPLE: iteration 1
smoothSolver:  Solving for Ux, Initial residual = 8.36789e-05, Final residual = 4.06971e-17, No Iterations 5
smoothSolver:  Solving for Uy, Initial residual = 2.64402e-05, Final residual = 4.01883e-17, No Iterations 5
smoothSolver:  Solving for T, Initial residual = 9.13109e-09, Final residual = 7.86405e-09, No Iterations 5
HeliumConstRho updates thermal properties...
Updating G, magG and B...
min/max(T) = 1.95, 1.95397
GAMG:  Solving for p, Initial residual = 4.87185e-07, Final residual = 6.67495e-09, No Iterations 5
GAMG:  Solving for p, Initial residual = 6.6887e-09, Final residual = 1.18949e-10, No Iterations 5
time step continuity errors : sum local = 3.43234e-14, global = 1.20386e-21, cumulative = 2.39346e-19
--> FOAM Warning :
    From function static bool Foam::IOobject::fileNameComponents(const Foam::fileName&, Foam::fileName&, Foam::fileName&, Foam::word&)
    in file db/IOobject/IOobject.C at line 131
     called with directory: "100"
    From function Foam::IOobject::IOobject(const Foam::fileName&, const Foam::objectRegistry&, Foam::IOobject::readOption, Foam::IOobject::writeOption, bool, bool)
    in file db/IOobject/IOobject.C at line 279.
FOAM exiting
The 100 catalogue was written but I cannot restart the simulation
and I started from 90 s. Also I change writeInterval to 200.
Now at 290 s I got the same as at the 90 s.
I am trying to start from 290 s (which is written) but I get this
Time = 290
Courant Number mean: 3.33408e-09 max: 3.34072e-08
deltaT = 1.2e-10
PIMPLE: iteration 1
smoothSolver:  Solving for Ux, Initial residual = 2.32946e-10, Final residual = 4.085e-17, No Iterations 5
smoothSolver:  Solving for Uy, Initial residual = 3.60056e-09, Final residual = 4.02081e-17, No Iterations 5
smoothSolver:  Solving for T, Initial residual = 4.09535e-06, Final residual = 6.28013e-14, No Iterations 5
GAMG:  Solving for p, Initial residual = 0.997946, Final residual = 6.70672e-08, No Iterations 36
GAMG:  Solving for p, Initial residual = 3.14035e-08, Final residual = 1.16862e-08, No Iterations 5
time step continuity errors : sum local = 5.38063e-22, global = -1.58036e-28, cumulative = -1.58036e-28
--> FOAM Warning :
     called with directory: "290"
FOAM exiting
Does anybody know what is going on?
best regards
pblasiak
gaza is offline   Reply With Quote
Old   October 4, 2018, 06:11
Przemek
when I changed 290 dir into 0 via
mv 290 0
it works now
but why????
best regards
pblasiak
Old   December 7, 2018, 06:36
Przemek
Originally Posted by gaza View Post
Hi All,
the write at 100 s:
Time = 100
deltaT = 0.00030688
PIMPLE: iteration 1
--> FOAM Warning :
FOAM exiting
Time = 290
deltaT = 1.2e-10
PIMPLE: iteration 1
--> FOAM Warning :
FOAM exiting
OK I found the reason of the error.
I had in the code (inside function that returns Pair<tmp<volScalarField> > object) this piece of code:
    mCondDotP_ = -mCoeff_*min(T_ - TSat_,T0);
    mEvapDotP_ = -mCoeff_*max(T_ - TSat_,T0);
    tmp<volScalarField> tmCondDotP
        new volScalarField
            IOobject
                U_.time().timeName(),
                U_.db(),
                IOobject::NO_READ,
                IOobject::NO_WRITE
            mCondDotP_
 tmp<volScalarField> tmEvapDotP
        new volScalarField
            IOobject
                U_.db(),
                IOobject::NO_READ,
                IOobject::NO_WRITE
            mEvapDotP_
    return Pair<tmp<volScalarField> >
        tmCondDotP,
        tmEvapDotP
I changed this into
        -mCoeff_*min(T_ - TSat_,T0),        -mCoeff_*max(T_ - TSat_,T0)
and now it works well.
best regards
pblasiak
Old   March 10, 2020, 12:53
Przemek
Hi
I have once again problem with tmp object.
Now the problem line is
tmp<volScalarField> tGMpGrest
        superFluid->GM()/rho/cp
rho and cp are volScalarFields
GM() function is defined as follow
Foam::tmp<Foam::volScalarField> Foam::myClass::GM() const
    if (GM_)
        return
               viscosityModelPtr_->AGM()*rhon_*rhos_*
               pow
                   max
                       B_*magG_,
                         dimensionedScalar("small", dimensionSet(0,1,-1,0,0,0,0), SMALL)
                   4.0
where B_, magG_, rhon_, rhos_ are volScalarFields
and viscosityModelPtr_->AGM() returns volScalarFields
my question is:
Is it proper way of returning tmp object in GM()?
Or Am I doing something wrong?
because I get error:
Time = 2.2
Courant Number mean: 0.00017481894698672 max: 0.00069651797368032
PIMPLE: iteration 1
smoothSolver:  Solving for Ux, Initial residual = 0.00014181233747096, Final residual = 3.7125624884409e-17, No Iterations 5
smoothSolver:  Solving for Uy, Initial residual = 0.0026592937137461, Final residual = 3.9760413783569e-17, No Iterations 5
--> FOAM Warning :
     called with directory: "2.2"
I tried to change GM() according to this
https://openfoamwiki.net/index.php/O..._you_use_it.3F
where we see
 tmp<largeClass> myFunc()
     tmp<largeClass> tReturnMe(new largeClass);
     largeClass& returnMe = tReturnMe();
     // Somehow fill the data in returnMe
     return tReturnMe;
so I applied this
    if (GM_)
        tmp<volScalarField> tReturnMe
               pow
                   max
                       B_*magG_,
                   4.0
        return tReturnMe;
however it did not help
Can anybody have some advice?
best regards
pblasiak
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
Fatal error: invalid wall function specification kcc49 OpenFOAM Running, Solving & CFD 13 September 26, 2018 05:07
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
