icoFoam pressures for solid-fluid coupled system |
October 1, 2018, 23:57 |
Kahlil Fredrick Cui
Rep Power: 8 |
Hello!
I am simulating particle flow in a fluid domain. The particles move in cyclic boundaries while the fluid is stationary and merely reacts to the particle motion (the image of the system is attached below). The fluid part is solved using icoFoam. I set the fluid BCs at both left, right and top walls as totalPressure for pressure and pressureInletOutletVelocity for velocity because I want the fluid to come in and out of the domain freely. The problem is this, when I set the fluid domain boundaries exactly at the same size as the particle boundaries I get a strong positive pressure in the left (in) and a negative pressure at the right (out). But when I extend the flow-wise boundaries a little bit, the positive pressure disappears and now I have two negative pressures at both ends. I have attached the images of the pressures below. I am thinking its a numerical effect, but I still cannot wrap my head about how pressures are discretized and solved. Personally, I find the positive pressures to be abnormal but I also cannot find any reason why negative pressures will develop at both ends and not only on one. Or maybe my BCs are wrong altogether. I would really appreciate any ideas and advice you can give me (I'm kinda running desperate already). Thanks in advance! |
Fluid Thermal 2-way System Coupling Dynamic Memory Allocation Error | Tiger23 | CFX | 6 | February 8, 2020 01:25 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 18:38 |
[ANSYS Meshing] error updating cell mesh in System Fluid Flow | Ema40 | ANSYS Meshing & Geometry | 3 | December 9, 2014 03:49 |
fluid mass in coupled FSI system | Dr. V. Kumar | CFX | 10 | July 16, 2007 11:23 |
interfced coupled system | jabe | CFX | 4 | April 22, 2002 20:28 |
