Impeller: temperature decreasing, should be increasing |
June 5, 2020, 16:13 |
#21 |
Charlie Marshall
Rep Power: 6 |
Thanks a lot!
I see that I should have changed all the related p_rgh to 1e5, especially the surrounding fixedFluxPressure, not just the internalField and the outlet. Cheers! Please let me know if you need any help in the future. Gonna test the more difficult scenarios. Regards, Charlie |
March 10, 2024, 19:15 |
OpenFOAM simulation of a compressor, rhoSimpleFOAM
#22 |
Alex
I am facing the same problem of above. I am running a CFD simulation in OpenFOAM (v10) of a compressor, working fluid perfect gas. The solver is rhoSimpleFOAM, MRF approach, omega = 1500 rad/s , the pressure and velocity fields are correctly simulated, while the Temperure does not increase as it should, it remains almost constant. could you kindly give me a hand? |
compressible, impeller, temperature bc |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 10:20 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 17:00 |
unexpected constant Temperature on a clip surface | Sungki | OpenFOAM Running, Solving & CFD | 0 | August 4, 2015 04:50 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
temperature increasing at zero heatflux wall | dokeun | FLUENT | 0 | May 26, 2011 00:33 |
