Error: Thermophysical results rhoCentralDyMFoam
Old   September 26, 2018, 02:24
Default Error: Thermophysical results rhoCentralDyMFoam
Bungalally is on a distinguished road
Hi all,
I am running into an an error trying to run rhoCentralDyMFoam for a two body 6dof case in the compressible regime.
The error appears to be from the way I am handling the thermo-physical modelling but I can't seem to work it out myself.
I have attached my case.
The error I receive is:
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in /lib64/libc.so.6
#3  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::
sensibleInternalEnergy> > > >::calculate(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Fo
am::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricFi
eld<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, bool) at ??:?
#4  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::
sensibleInternalEnergy> > > >::correct() at ??:?
#5  ? at ??:?
#6  __libc_start_main in /lib64/libc.so.6
#7  ? at ??:?
Floating point exception (core dumped)
Thank you in advance
Bungalally is offline   Reply With Quote
rhocentralfoam
OpenFOAM - Validation of Results Ahmed OpenFOAM Running, Solving & CFD 10 May 13, 2018 19:28
lid driven cavity varying results yasmil OpenFOAM Running, Solving & CFD 2 October 6, 2016 22:42
interFoam simulation yields inconsistent results for alpha1 surface Ralinus OpenFOAM Running, Solving & CFD 8 January 13, 2014 09:54
CFD results not close to experimental results cider STAR-CCM+ 0 July 8, 2013 08:53
CFX cylinder or sphere benchmark results Mel CFX 1 August 8, 2005 19:47
