Results from RANS and LES look completely different |
September 25, 2018, 07:52 |
ssa
Rep Power: 8 |
Hi all,
I have done a simulation, flow around buildings, using pimpleFoam and RANS (Kepsilon model). The results were good. But when I run the same simulation with LES (Keqn model), the results are completely different. Does anyone have idea, how to solve this.? Thanks. |
September 25, 2018, 09:37 |
Uwe Pilz
Rep Power: 15 |
One of the main tasks in simulations is to ensure the correctness of the results. Or, more accurate, to get a feeling of the uncertainty.
I recommend that you first used both methods again geometries where an analytical or exactly measured solutions exists. You will find deviation to a more or lesser degree. Then you need to find out how to minimize them by changing the parameters of your model.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
September 25, 2018, 09:52 |
ssa
Rep Power: 8 |
Hi Uwe Pilz,
I have experimental data from a journal, and I have compared the results from RANS simulations which are agreeable. But in case of LES simulations, even the flow field is not matching. To be clear, according to the experiment the flow should move down in between the buildings, but in my case, the flow moves up. The LES simulations are completely not acceptable. Thanks. |
September 26, 2018, 06:15 |
Peter Baskovich
Rep Power: 12 |
Have you tried initialising the LES case with the RANS results? Try mapFields for U and p fields at least and see if it's a issue with initial value sensitivity. Can you also post the 0 directory for each case, if not the whole case (both)?
September 26, 2018, 06:53 |
#5 | |
ssa
Rep Power: 8 |
I have not tried mapping fields. I will try to do that. In 0 folder I have not done any changes. They are same for both LES and RANS. I have just changed the turbulence properties file in case of LES. I have always used RANS simulation and I am new to LES. What parameters should be changed.? Quote:
September 26, 2018, 12:26 |
Gurpinder Singh Basra
Rep Power: 8 |
For comparing results, are you comparing values for U for each case? If that is the case try comparing U from RANS and Umean from LES, that should give you some similar results since doesn't resolve eddies but LES U value do show LES. |
September 27, 2018, 04:29 |
ssa
Rep Power: 8 |
Hi basrag,
Yes I am comparing the time averaged velocity field from LES, still the results are different from RANS. |
September 27, 2018, 08:17 |
Tobias Holzmann
Rep Power: 52 |
I just want to make a statement. Even if you are using RANS with another turbulence model, you will see that the results are different too; or change the mesh size. Are you using the same grid? Can the grid resolve the large-scaled vortexes? In general, the solution should definitely be more chaotic based. A good example can be found from Jószef Nagy. He is using the pitzDaily case and made an analysis with different turbulence models.
Keep foaming, Tobias Holzmann |
Worse accuracy in LES models than in RANS models | dferrando | OpenFOAM Running, Solving & CFD | 0 | August 30, 2017 05:56 |
LES Simulation from RANS results | AS_Aero | STAR-CCM+ | 1 | May 24, 2017 14:12 |
Model Switch, RANS to LES? | jennap223 | STAR-CCM+ | 0 | July 7, 2015 12:30 |
LES VS RANS results | sharonyue | OpenFOAM Running, Solving & CFD | 4 | March 15, 2015 14:15 |
RANS results for LES | Li Yang | Main CFD Forum | 5 | June 17, 2002 06:34 |
