twoPhaseeulerfoam case setup
Old   September 24, 2018, 14:47
Default twoPhaseeulerfoam case setup
krishnan
tankerp is on a distinguished road
I have a question regarding a spray simulation of diesel in air. The data from the experiments performed elsewhere states that air in introduced in the nozzle system at a flow rate of 150 LPM & pressure of 10 bar. The outlet is at ambient pressure. Can I set both the pressure and velocity at the inlet? The flow is compressible in the nozzle system.
tankerp is offline   Reply With Quote
spray atomization, twophaseeulerfoam
Can`t Setup ONERA optimization case McAero SU2 6 November 15, 2017 09:29
Uncommon stirrer case simulation setup fatal_error CFX 2 July 19, 2015 07:46
pimpleDyMFoam case setup sivakumar OpenFOAM Pre-Processing 0 December 11, 2013 07:24
Duct case setup - Fan simulation nkjsimulating Main CFD Forum 0 October 10, 2013 05:15
OpenFOAM case setup and work flow - what are you using? Arnoldinho OpenFOAM Pre-Processing 4 July 18, 2010 10:16
