compressibleInterFoam exits without warning or error
Old   September 22, 2018, 18:14
Default compressibleInterFoam exits without warning or error
Obi
obiscolly50 is on a distinguished road
I'm experiencing a problem of compressibleInterFoam solver exiting when i try to restart from a non-zero time (latestTime). Starting the simulation from 0 works just fine. But say i stop at 0.1 and try to start from latestTime, the solver exits. This is the same for both series and parallel runs. Anyone has an idea of what's going on? Here's the code i'm getting:
obi@Obi:/mnt/d/linux/rootfs/opt/openfoam6/tutorials/multiphase/compressibleInterFoam/laminar/depth$ compressibleInterFoam
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  6
     \\/     M anipulation  |
Build  : 6-1a0c91b3baa8
Exec   : compressibleInterFoam
Date   : Sep 22 2018
Time   : 15:48:37
Host   : "Obi"
PID    : 447
I/O    : uncollated
Case   : /mnt/d/linux/rootfs/opt/openfoam6/tutorials/multiphase/compressibleInterFoam/laminar/depth
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0.01
PIMPLE: No convergence criteria found
PIMPLE: No corrector convergence criteria found
        Calclations will do 3 corrections
Reading field p_rgh
Reading field U
Constructing twoPhaseMixtureThermo
Selecting surfaceTensionModel liquidProperties
Selecting thermodynamics package
    type            heRhoThermo;
    mixture         pureMixture;
    properties      liquid;
    energy          sensibleInternalEnergy;
    type            heRhoThermo;
    transport       const;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
Reading thermophysical properties
Reading g
Reading hRef
Calculating field g.h
Restarting alpha
Selecting turbulence model type laminar
Selecting laminar stress model Stokes
Creating field kinetic energy K
No MRF models present
No finite volume options present
Courant Number mean: 0.11987808 max: 0.45361393
Starting time loop
Interface Courant Number mean: 0.0054768835 max: 0.41423052
deltaT = 0.00033333333
Time = 0.01033333333
PIMPLE: Iteration 1
MULES: Solving for alpha.water
Phase-1 volume fraction = 0.48394679  Min(alpha.water) = -3.8593614e-13  Max(alpha.water) = 1
Phase-1 volume fraction = 0.48400956  Min(alpha.water) = -3.6033325e-13  Max(alpha.water) = 1
smoothSolver:  Solving for T, Initial residual = 0.0024525484, Final residual = 6.7194677e-10, No Iterations 5
obiscolly50 is offline   Reply With Quote
Old   September 23, 2018, 20:44
Default Workaround and Sample
Peter Brady
pbrady2013 is on a distinguished road
Hey,
Can you post a small sample to reproduce on another machine, OS, version?
Failing that, I don't use compressible much but I do inter, I tend to run my restarts in a new case folder and copy the 0.1 fields into the 0 folder of my new case and have see no weirdness like you describe.
Cheers,
-pete
pbrady2013 is offline   Reply With Quote
Old   September 23, 2018, 20:58
Obi
Originally Posted by pbrady2013 View Post
Hey,
Cheers,
-pete
Hi Pete,
Thanks for the reply. I'm just test running the depthCharge2D tutorial available under compressibleInterFoam. I haven't made any changes to the parameters, except controlDict where i specify the start and end times.
When doing the restarts as you mentioned, is it necessary to delete any files from the last time step?
Old   September 24, 2018, 05:27
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Originally Posted by obiscolly50 View Post
..., is it necessary to delete any files from the last time step?
No you dont have to delete any file. That would be funny otherwise
Based on your output, I cannot see any abort nor error/warning. Probably you are doing anything wrong.
- Which FOAM version are you using
- What did you do? I guess starting from 0 to 0.1 (endTime)
- Restart with 0.1 (startTime)
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   September 24, 2018, 10:57
Obi
Originally Posted by Tobi View Post
Hi Tobi,
I'm currently using OpenFoam 6. In the past, I've used v1706 and restarted simulations from the last time step with no issues.
As you said, I ran from 0 to 0.1s, but restarting with 0.1 as new startTime and 0.2 as end time takes me back to the prompt without completing a full iteration or producing any errors or warning. But running from 0 to 0.2 s produces no problem which is quite weird.
Old   September 24, 2018, 12:39
Tobi's Avatar
Tobias Holzmann
Give me one moment. I will check it.
Keep foaming,
Tobias Holzmann
Old   September 24, 2018, 12:42
Tobi's Avatar
Tobias Holzmann
Here we go. No problems:
Create time
Create mesh for time = 0.1
Reading field p_rgh
Reading field U
    type            heRhoThermo;
    properties      liquid;
    type            heRhoThermo;
    transport       const;
    thermo          hConst;
    specie          specie;
Reading g
Reading hRef
Restarting alpha
Courant Number mean: 0.10664387 max: 0.48430098
Starting time loop
Interface Courant Number mean: 0.0085487643 max: 0.47101548
deltaT = 0.00034482759
Time = 0.1003448276
PIMPLE: Iteration 1
Phase-1 volume fraction = 0.4845822  Min(alpha.water) = -1.4207953e-05  Max(alpha.water) = 1
Phase-1 volume fraction = 0.48454596  Min(alpha.water) = -1.3415277e-05  Max(alpha.water) = 1
smoothSolver:  Solving for T, Initial residual = 0.00011731011, Final residual = 3.5544292e-09, No Iterations 2
GAMGPCG:  Solving for p_rgh, Initial residual = 0.030081878, Final residual = 1.7224384e-08, No Iterations 5
PIMPLE: Iteration 2
Phase-1 volume fraction = 0.48461754  Min(alpha.water) = -1.4333223e-05  Max(alpha.water) = 1
Phase-1 volume fraction = 0.48461936  Min(alpha.water) = -1.3581991e-05  Max(alpha.water) = 1
smoothSolver:  Solving for T, Initial residual = 4.0596051e-05, Final residual = 9.4069755e-10, No Iterations 2
GAMGPCG:  Solving for p_rgh, Initial residual = 0.004244985, Final residual = 5.497686e-08, No Iterations 4
PIMPLE: Iteration 3
Phase-1 volume fraction = 0.48461802  Min(alpha.water) = -1.4279122e-05  Max(alpha.water) = 1
Phase-1 volume fraction = 0.48461882  Min(alpha.water) = -1.3483091e-05  Max(alpha.water) = 1
smoothSolver:  Solving for T, Initial residual = 8.1976307e-06, Final residual = 4.3512811e-10, No Iterations 2
GAMGPCG:  Solving for p_rgh, Initial residual = 0.00082954307, Final residual = 8.5665535e-08, No Iterations 3
ExecutionTime = 0.27 s
Courant Number mean: 0.10793185 max: 0.49006626
Interface Courant Number mean: 0.0086214425 max: 0.478485
Time = 0.1006896552
- Starting from 0 to 0.1s
- StartTime = 0.1 s to endTime 0.2 s
- Output as above.
Keep foaming,
Tobias Holzmann
Old   September 24, 2018, 12:59
Obi
- Output as above.
Thanks for looking into it. I'm now suspecting there might be a problem with my installation. I'm not sure reinstalling will help. What version do you use?
Old   September 24, 2018, 13:13
Tobi's Avatar
Tobias Holzmann
I use the dev branch of the Foundation version. I did not have time to check weather there was a commit on this or not. However, I guess it was not a code problem. It should be related to your installation. But the funny thing is, that you get back to the prompt without any error/warning or even an output of foam. Would be interesting to see in which peace of the code it leaves the program.
You can also check other solvers such as rhoPimpleFoam. If the behavior is the same, it should be related to you installation.
Keep foaming,
Tobias Holzmann
Old   September 11, 2020, 11:10
lpp
imech is on a distinguished road
     \\/     M anipulation  |
Date   : Sep 22 2018
Time   : 15:48:37
Host   : "Obi"
PID    : 447
I/O    : uncollated
nProcs : 1
Create time
Reading field p_rgh
Reading field U
    type            heRhoThermo;
    properties      liquid;
    type            heRhoThermo;
    transport       const;
    thermo          hConst;
    specie          specie;
Reading g
Reading hRef
Restarting alpha
Starting time loop
PIMPLE: Iteration 1
have you solved this problem?
imech is offline   Reply With Quote
Old   June 16, 2023, 05:37
Default CompressibleInterFoam stopping without giving any error
  #11
Shanu
chaudhad is on a distinguished road
Hi guys, I know it is an old post but I am stuck for a very long time. Actually, I am simulating a 2phase flow in a cylinder where initially air is filled and water is moved inside the cylinder with a constant velocity to compress the air. Simulations have already been done with blaockMesh utility to generate a mesh and they have come up with a result that matches the experimental results. Now we want to do some modifications in the geometry like adding some cooling pipes and then simulating the flow. Since the geometry is a bit complicated, I decided to use snappyHexMesh to mesh my geometry. but it seems like whenever I try to make my mesh fine by adding more boundary layers like 15 in this case, the simulation stops without giving any warning. I am still unable to validate the previous simulation done with blockMesh when I am using snappyHExMesh on the same geometry. Coarse Mesh gives results differently and whenever I try to make my mesh refined the simulation stops. I am using the LES turbulence model for my case. I have attached everything in the post. Please if someone can help, it will be highly appreciated. I have attached log files of the simulation as well.
error
Courant Number mean: 0.0014648472 max: 0.18931605
Interface Courant Number mean: 1.6251368e-05 max: 0.1644763
deltaT = 0.00028510116
Time = 0.00335071
Phase-1 volume fraction = 0.00012129885 Min(alpha.water) = -0.077692331 Max(alpha.water) = 1
Phase-1 volume fraction = 0.00012668907 Min(alpha.water) = -0.081284766 Max(alpha.water) = 1
checkMesh
Checking geometry...
Overall domain bounding box (-0.025900001 -0.025892001 -5.74917e-18) (0.025900001 0.025892001 0.90600002)
Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
Mesh has 3 solution (non-empty) directions (1 1 1)
Boundary openness (-5.0241235e-18 -4.1763932e-17 -3.4894248e-17) OK.
Max cell openness = 8.8521418e-16 OK.
Max aspect ratio = 20.398317 OK.
Minimum face area = 2.7732229e-07. Maximum face area = 3.0123228e-05. Face area magnitudes OK.
Min volume = 6.6540004e-10. Max volume = 1.1361717e-07. Total volume = 0.0019039706. Cell volumes OK.
Mesh non-orthogonality Max: 38.107286 average: 4.9532135
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 0.43586216 OK.
Coupled point location match (average 0) OK.
Mesh OK.
End
0 folder
alphat
boundaryField
"(cylinderWalls|topX|bottomX|topY|bottomY|topZ|bot tomZ)"
type compressible::alphatWallFunction;
value uniform 0;
pipeWalls
value uniform 0;
top
value uniform 0;
inlet
type calculated;
value uniform 0;
nut
boundaryField
type nutUWallFunction;
value uniform 0;
pipeWalls
value uniform 0;
top
value uniform 0;
inlet
type calculated;
value uniform 0;
simulation.txt
fvScheme.txt
fvsolution.txt
snappyHex.txt
chaudhad is offline   Reply With Quote
compressibleinterfoam
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 08:43
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 05:53
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
