wallHeatTransferCoeff in chtMultiRefionFoam OF6 not working
Old   September 18, 2018, 11:09
Default wallHeatTransferCoeff in chtMultiRefionFoam OF6 not working
Muhammad Waqas
mwaqas is on a distinguished road
Send a message via Skype™ to mwaqas
Hello Everyone,
In chtMultiRegionFoam, I want to calculate heat transfer coefficient. OpenFOAM has introduced "wallHeatTransferCoeff" function object in OF6 to calculate heat transfer coefficient directly. Here is the link
I am trying to test this function. Hence, I have only included following function in controlDict to calculate the wall heat transfer coefficient.
functions
wallHeatTransferCoeff1
type wallHeatTransferCoeff;
libs ("libfieldFunctionObjects.so");
region bottomWater;
rho 1.225;
Cp 1005;
Prl 0.707;
Prt 0.9;
But I am getting following error
[0] --> FOAM FATAL ERROR:
[0] Unable to find incompressible turbulence model in the database[1]
[1]
[1] --> FOAM FATAL ERROR:
[1] Unable to find incompressible turbulence model in the database
[1]
[1] From function virtual bool Foam::functionObjects::wallHeatTransferCoeff::exec ute()
[1] in file wallHeatTransferCoeff/wallHeatTransferCoeff.C at line 227.
It seems like wallHeatTransferCoeff has not been for chtMultiRegionFoam, but realease note of OF6 specially mentions that it could be used to calculate heat transfer coefficient in multi-regio simulation.
Did anyone try this function? Am I missing something or making a mistake?
I took OF6 multiRegionHeater tutorial, I didn't change anything in tutorial at all
Thank you
Regards
mwaqas is offline   Reply With Quote
Old   September 19, 2018, 03:50
Bloerb will become famous soon enough
This was made for incompressible solvers. Hence your error message. While chtMultiRegion can calculate incompressible flow it is still a compressible solver (which allows the user to set a constant density). If you follow the link you gave to the commit you can read
wallHeatTransferCoeff: New functionObject to calculate the wall heat …
…transfer coefficient
for incompressible flow simulated using simpleFoam, pimpleFoam or pisoFoam.
Now these solvers can be used with a -region option, but are not conjugate solvers.
This function object calculates this in the following fashion:
            wallHeatTransferCoeffBf[patchi] =
                rho_*Cp_*(nuBf[patchi]/Prl_ + nutBf[patchi]/Prt_);
It should be easy to calculate this in ParaView or via your own (coded) function object for compressible flow
Bloerb is offline   Reply With Quote
Old   September 19, 2018, 06:21
Muhammad Waqas
Hi Bloerb,
Thank you for your reply.
wallHeatTransferCoeff: New functionObject to calculate the wall heat transfer coefficientfor incompressible flow
You are absolutely right, it is mentioned over there that it is for incompressible flow but I couldn't find that it is only for flow using using simple. pimple or pisoFoam.
What I could find is:
Data Processing: function objects for individual regions in a multi-region simulation [ commit a5a034 ]; wallHeatTransferCoeff function object to calculate the wall heat transfer coefficient [ commit 99841e ];
It is meant for multiRegion (off course incompressible) and as per my understanding from this link, there is only one solver for multiregion in OF-6 i.e. chtMulriRegionFoam (they have combined both chtMulriRegionSimpleFoam and chtMulriRegionFoam in one solver i.e chtMulriRegionFoam) and chtMulriRegionFoam is by default for compressible fluid.
Solvers: chtMultiRegionFoam conjugate heat transfer (CHT) solver runs both steady-state and transient solutions (deprecating chtMultiRegionSimpleFoam) [ commit 283f8b ]; added option for reactions and combustion to chtMultiRegionFoam [ commit 7c237a ].
Then how could we use wallHeatTransferCoeff for multi-region?
Regards
Old   September 19, 2018, 09:54
As I said, you can't use it with this solver without programming your own utility
Old   September 17, 2020, 13:17
giovanni
gian93 is on a distinguished road
Could someone explain the formula used for heat transfer coefficient mentioned above? I want to use it for an incompressioble simulation with water trough pipes . Water is at 100C and the solver used is simpleFoam. I want to visualize the "virtual" heat transfer coefficient at walls . I think that I have set correctly the function object in the controlDict :
        //region      fluid;
        //patches     (".*Wall");
        rho         997;
        Cp          4215.7;
        Prl         1.64;
        Prt         0.9;
the problem is that paraFoam shows me very small heat transfer coefficient... (it should be on the order of 3*10^4 but mine are on the order of 5*10^0)..
what I have missed? thanks
gian93 is offline   Reply With Quote
InterFoam: Different results in OF5 and OF6 vatavuk OpenFOAM Bugs 19 January 26, 2021 18:22
findCell() in parallel: not working if location is outside the domain TobiWol OpenFOAM 0 January 10, 2018 15:33
Processor 0 not working vishwesh OpenFOAM Running, Solving & CFD 0 November 17, 2017 04:35
DPM parallel is not working but serial is working johnwinter FLUENT 1 March 27, 2012 03:01
Working directory mgonzalo FLUENT 1 November 11, 2011 11:05
