usefulness of consistent mapField to speed up convergence?
Old   September 17, 2018, 19:02
Default usefulness of consistent mapField to speed up convergence?
Jeff
jf_vt is on a distinguished road
Hi
I was under the ( possibly wrong) impression that one of the uses of mapField was to generate an initial guess on a fine mesh from a converged solution on a coarser mesh that will allow for faster convergence, as illustrated by the cavity exemple in the documentation.
The reason of this post is that based on this assumption I tried to use mapField in a complicated and large 3d unstructured grid with acceptable orthogonality quality ( max orthogonality is always under 64 and average around 40) and all checkmesh test are passed for all grids without errors.
The solver is a variation on simpleFoam with basic k-epsilon model and wall function treatment.
Both cases converge slowly but steadily if I use potentialFoam to generate an initial guess.
I am trying to speed up convergence of larger case using smaller case solution and I fail miserably:
Indeed, if I use mapField -consistent with a converged solution on a coarser mesh as source, the utility works but then the case blow up very quickly even if I strongly lower the relaxation factors.
So my question:
Is there some known limit to the use of mapField to speed up convergence after a mesh refinement?
maybe my refinement is too agressive as number of mesh on the fine mesh is ~3X ( 9 10^6 for the coarse mesh and 26 10^6 for the finer one)?
is there some options to "smooth" the initial guess i am ignorant of?
Other?
I searched this forum and google before posting but found no discussion of such limit. Apololgies if I missed something.
Thanks
JF
jf_vt is offline   Reply With Quote
Is solution converged?(Judging convergence)? aja1345 FLUENT 4 February 26, 2016 07:09
Convergence speed in free surface simulations Chebeba CFX 13 July 23, 2009 14:08
Defect correction and convergence ganesh Main CFD Forum 4 June 30, 2006 15:20
speed up convergence for drag Aymeric CFX 1 March 8, 2006 19:56
Convergence Speed Maciej Matyka Main CFD Forum 1 June 12, 2003 13:20
