Scalar field blows up (only) after restarting the simulation |
September 15, 2018, 00:32 |
Anonymous
Rep Power: 10 |
I have a modified form of pimpleFoam where I have added a source/sink term in it (TEqn) to make the temperature field periodic in periodic flows. So far so good. I initialize the T field with a uniform value everywhere and start the simulation. It runs and after few flow-passes, I can obtain a fully developed T-profile. No blowing up at all. Now when I stop the simulation and try to re-run it, the T field blows up at places where the grid is too fine. Please note that if I didn't stop the original simulation and had let in run, it won't crash. The trouble is just with stopping and rerunning the simulation with the developed T-profile. Any ideas how to tackle this issue? Thanks, |
September 15, 2018, 09:12 |
Peter Baskovich
Rep Power: 12 |
Hi Spockner,
Can you share more information, the case and the solver would be ideal if you can share them. Otherwise, have you got an under-relaxation term on your sink/source? When restarting a case there is often no cached fields (grad(U)) so the initial residuals/ continuity error can be larger in the first few steps than when the same job stopped. This may be causing your active sink/source to overreact. |
September 16, 2018, 02:24 |
#3 | |
Anonymous
Rep Power: 10 |
Thanks Peter, I am attaching the TEqn for you to refer to my source/sink term. I am not able to access my case right now, but to let you know I did not use any under-relaxation for my T field so far. I will try it tomorrow to see if that helps. Please take a look attached TEqn... |
September 16, 2018, 07:56 |
Peter Baskovich
Rep Power: 12 |
For good measure, it is common to use a limitTemperature constraint in fvOptions with some limits a little outside of what you're expecting. This can help get past the first few iterations without crashing.
Howto use scalarCodedSource in fvOptions | hanness | OpenFOAM Running, Solving & CFD | 61 | November 18, 2022 13:11 |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 08:15 |
Steady simulation does not iterate in Time=1 | agustinvo | OpenFOAM Running, Solving & CFD | 3 | November 19, 2015 05:57 |
Passive scalar in "frozen" field | mrcsjnssn | FLUENT | 3 | October 5, 2015 10:41 |
restarting paused transient simulation using reactingFoam | JMDag2004 | OpenFOAM Running, Solving & CFD | 1 | August 10, 2015 11:15 |
