Residuals and forces spiraling out of control before failing |
September 6, 2018, 19:34 |
Ed O'Malley
Rep Power: 9 |
Hi -
I'm running an external aerodynamics simulation of a leg in a cycling shoe. Previous models worked fine but my new geometry fails when running simpleFoam with this error: mpirun detected that one or more processes exited with non-zero status, thus causing the job to be terminated. The first process to do so was: Process name: [[1404,1],1] Exit code: 145 In the Log.simpleFoam file for the new geometry (and in the forces.dat file) the forces and moments quickly start to spiral way way out of bounds in just a couple time steps (by E^22) and residuals go up. Below is the new simpleFoam log. Total force in the x direction in previous models stayed between 0.2 and 1.5 through every time step. Any idea where I should look for the error? Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1706 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : v1706-17752679325a Arch : "LSB;label=32;scalar=64" Exec : simpleFoam -decomposeParDict system/decomposeParDict.6 -parallel Date : Sep 06 2018 Time : 15:48:54 Host : "DESKTOP-1A6ON5E" PID : 1016 Case : /mnt/c/Users/edoma/CFD/ShoeCFD/ShoeCases/LuckBlankCase nProcs : 6 Slaves : 5 ( "DESKTOP-1A6ON5E.1017" "DESKTOP-1A6ON5E.1018" "DESKTOP-1A6ON5E.1019" "DESKTOP-1A6ON5E.1020" "DESKTOP-1A6ON5E.1021" ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: no convergence criteria found. Calculations will run for 160 steps. Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kOmegaSST Selecting patchDistMethod meshWave RAS { RASModel kOmegaSST; turbulence on; printCoeffs on; alphaK1 0.85; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.856; gamma1 0.555556; gamma2 0.44; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; b1 1; c1 10; F3 false; } No MRF models present No finite volume options present Starting time loop streamLine streamLines: Employing velocity field U automatic track length specified through number of sub cycles : 5 nearWallFields near: Sampling 1 fields wallBoundedStreamLine wallBoundedStreamLines: Employing velocity field UNear wallBoundedStreamLine wallBoundedStreamLines: Reading surface description: yNormal forces forces: Not including porosity effects forces forceCoeffs1: Not including porosity effects forceCoeffs forceCoeffs1: Not including porosity effects Time = 1 smoothSolver: Solving for Ux, Initial residual = 0.135244, Final residual = 0.0131051, No Iterations 7 smoothSolver: Solving for Uy, Initial residual = 0.221967, Final residual = 0.021706, No Iterations 7 smoothSolver: Solving for Uz, Initial residual = 0.102955, Final residual = 0.00947569, No Iterations 6 GAMG: Solving for p, Initial residual = 1, Final residual = 0.0083848, No Iterations 6 time step continuity errors : sum local = 0.00339492, global = 0.000131918, cumulative = 0.000131918 smoothSolver: Solving for omega, Initial residual = 0.00850392, Final residual = 0.000734336, No Iterations 2 bounding omega, min: -11305.7 max: 206538 average: 1191.11 smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.0528535, No Iterations 4 ExecutionTime = 24.31 s ClockTime = 42 s forces forces write: Sum of forces Total : (1.28156 -0.0580492 0.0871446) Pressure : (1.11856 -0.0592977 0.0782166) Viscous : (0.162997 0.00124855 0.00892796) Sum of moments Total : (0.00961546 0.275512 -0.0834014) Pressure : (0.00900869 0.246646 -0.0737632) Viscous : (0.000606767 0.0288652 -0.00963815) forceCoeffs forceCoeffs1 execute: Coefficients Cm : 1.24239 (pressure: 1.11222 viscous: 0.130164) Cd : 1.38697 (pressure: 1.21057 viscous: 0.176403) Cl : 0.0943123 (pressure: 0.08465 viscous: 0.00966229) Cl(f) : 1.28954 Cl(r) : -1.19523 Time = 2 smoothSolver: Solving for Ux, Initial residual = 0.88129, Final residual = 0.0111583, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.256073, Final residual = 0.00154053, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.527083, Final residual = 0.00880131, No Iterations 2 GAMG: Solving for p, Initial residual = 0.0732592, Final residual = 0.000555328, No Iterations 5 time step continuity errors : sum local = 0.00184624, global = 2.23016e-05, cumulative = 0.00015422 smoothSolver: Solving for omega, Initial residual = 0.0372897, Final residual = 0.00204077, No Iterations 4 bounding omega, min: -7.48187 max: 3.4135e+17 average: 1.37094e+12 smoothSolver: Solving for k, Initial residual = 0.0729652, Final residual = 0.00606091, No Iterations 1 ExecutionTime = 29.08 s ClockTime = 49 s forces forces write: Sum of forces Total : (1.08122 -0.0393872 0.0579338) Pressure : (0.938682 -0.0404867 0.0508137) Viscous : (0.142542 0.00109949 0.00712015) Sum of moments Total : (0.00535194 0.238972 -0.067452) Pressure : (0.00482941 0.211936 -0.05898) Viscous : (0.000522525 0.027036 -0.00847204) forceCoeffs forceCoeffs1 execute: Coefficients Cm : 1.07761 (pressure: 0.955698 viscous: 0.121916) Cd : 1.17016 (pressure: 1.01589 viscous: 0.154266) Cl : 0.0626989 (pressure: 0.0549931 viscous: 0.0077058) Cl(f) : 1.10896 Cl(r) : -1.04626 Time = 3 smoothSolver: Solving for Ux, Initial residual = 0.999998, Final residual = 0.0917034, No Iterations 7 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0823003, No Iterations 6 smoothSolver: Solving for Uz, Initial residual = 0.999999, Final residual = 0.082565, No Iterations 7 GAMG: Solving for p, Initial residual = 0.0631383, Final residual = 0.000538029, No Iterations 5 time step continuity errors : sum local = 356440, global = -472.975, cumulative = -472.975 smoothSolver: Solving for omega, Initial residual = 0.538479, Final residual = 1.56332e-09, No Iterations 1 bounding omega, min: -1.88285e+09 max: 1.02405e+17 average: 4.13461e+11 smoothSolver: Solving for k, Initial residual = 0.122809, Final residual = 0.00350588, No Iterations 1 ExecutionTime = 33.98 s ClockTime = 57 s forces forces write: Sum of forces Total : (8.33691e+06 3.45654e+06 5.12258e+06) Pressure : (8.28259e+06 3.41401e+06 5.06594e+06) Viscous : (54319.9 42528.7 56645.5) Sum of moments Total : (-188912 -252743 489737) Pressure : (-186260 -244123 480634) Viscous : (-2652.06 -8619.31 9103.32) forceCoeffs forceCoeffs1 execute: Coefficients Cm : -1.13971e+06 (pressure: -1.10084e+06 viscous: -38867.7) Cd : 9.02263e+06 (pressure: 8.96384e+06 viscous: 58787.8) Cl : 5.54392e+06 (pressure: 5.48262e+06 viscous: 61304.6) Cl(f) : 1.63225e+06 Cl(r) : 3.91167e+06 Time = 4 smoothSolver: Solving for Ux, Initial residual = 0.785908, Final residual = 0.0625646, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.699965, Final residual = 0.0391674, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 0.680457, Final residual = 0.0367154, No Iterations 3 GAMG: Solving for p, Initial residual = 0.995694, Final residual = 0.00887311, No Iterations 13 time step continuity errors : sum local = 494941, global = -10614, cumulative = -11086.9 smoothSolver: Solving for omega, Initial residual = 0.538423, Final residual = 2.00668e-06, No Iterations 1 smoothSolver: Solving for k, Initial residual = 0.129558, Final residual = 0.00799405, No Iterations 3 ExecutionTime = 40.09 s ClockTime = 66 s forces forces write: Sum of forces Total : (-2.52031e+16 -2.54231e+16 -2.72343e+16) Pressure : (-2.52031e+16 -2.54231e+16 -2.72343e+16) Viscous : (-4.10507e+06 -255696 538475) Sum of moments Total : (2.08799e+15 4.05448e+15 -5.71357e+15) Pressure : (2.08799e+15 4.05448e+15 -5.71357e+15) Viscous : (79809.7 -838476 244307) forceCoeffs forceCoeffs1 execute: Coefficients Cm : 1.82832e+16 (pressure: 1.82832e+16 viscous: -3.78101e+06) Cd : -2.7276e+16 (pressure: -2.7276e+16 viscous: -4.44272e+06) Cl : -2.94743e+16 (pressure: -2.94743e+16 viscous: 582766) Cl(f) : 3.546e+15 Cl(r) : -3.30203e+16 Time = 5 smoothSolver: Solving for Ux, Initial residual = 0.615272, Final residual = 0.0569642, No Iterations 6 smoothSolver: Solving for Uy, Initial residual = 0.617511, Final residual = 0.0560585, No Iterations 5 smoothSolver: Solving for Uz, Initial residual = 0.631485, Final residual = 0.0582229, No Iterations 5 GAMG: Solving for p, Initial residual = 7.91509e-06, Final residual = 9.35461e-08, No Iterations 12 time step continuity errors : sum local = 1.87307e+06, global = 48932, cumulative = 37845 smoothSolver: Solving for omega, Initial residual = 0.53741, Final residual = 3.92157e-05, No Iterations 1 smoothSolver: Solving for k, Initial residual = 0.0993691, Final residual = 0.00917355, No Iterations 3 ExecutionTime = 46.19 s ClockTime = 76 s forces forces write: Sum of forces Total : (-1.38778e+17 -1.96715e+17 -1.97628e+17) Pressure : (-1.38778e+17 -1.96715e+17 -1.97628e+17) Viscous : (-1.31761e+07 1.69993e+06 1.28548e+06) Sum of moments Total : (1.73308e+16 3.53724e+16 -4.67935e+16) Pressure : (1.73308e+16 3.53724e+16 -4.67935e+16) Viscous : (18760 -2.3801e+06 1.38128e+06) forceCoeffs forceCoeffs1 execute: Coefficients Cm : 1.59508e+17 (pressure: 1.59508e+17 viscous: -1.07328e+07) Cd : -1.50193e+17 (pressure: -1.50193e+17 viscous: -1.42599e+07) Cl : -2.13883e+17 (pressure: -2.13883e+17 viscous: 1.39121e+06) Cl(f) : 5.2566e+16 Cl(r) : -2.66449e+17 Time = 6 smoothSolver: Solving for Ux, Initial residual = 0.518912, Final residual = 0.0424792, No Iterations 57 smoothSolver: Solving for Uy, Initial residual = 0.535962, Final residual = 0.0534381, No Iterations 56 smoothSolver: Solving for Uz, Initial residual = 0.511037, Final residual = 0.0479979, No Iterations 58 GAMG: Solving for p, Initial residual = 0.82888, Final residual = 0.0438469, No Iterations 1000 time step continuity errors : sum local = 3.1669e+12, global = -5.86772e+06, cumulative = -5.82988e+06 smoothSolver: Solving for omega, Initial residual = 0.0766007, Final residual = 0.00538269, No Iterations 4 smoothSolver: Solving for k, Initial residual = 0.193746, Final residual = 0.016646, No Iterations 3 ExecutionTime = 233.67 s ClockTime = 364 s forces forces write: Sum of forces Total : (-6.51201e+22 3.71996e+22 6.49004e+22) Pressure : (-6.51201e+22 3.71996e+22 6.49004e+22) Viscous : (8.65424e+13 -7.22325e+13 -8.40083e+12) Sum of moments Total : (2.10418e+21 -1.26682e+22 9.40817e+21) Pressure : (2.10418e+21 -1.26682e+22 9.40817e+21) Viscous : (8.72937e+11 3.04271e+12 -1.67541e+13) forceCoeffs forceCoeffs1 execute: Coefficients Cm : -5.71255e+22 (pressure: -5.71255e+22 viscous: 1.37207e+13) Cd : -7.04763e+22 (pressure: -7.04763e+22 viscous: 9.36606e+13) Cl : 7.02386e+22 (pressure: 7.02386e+22 viscous: -9.0918e+12) Cl(f) : -2.20063e+22 Cl(r) : 9.22448e+22 Time = 7 smoothSolver: Solving for Ux, Initial residual = 0.667783, Final residual = 35.3377, No Iterations 1000 smoothSolver: Solving for Uy, Initial residual = 0.653949, Final residual = 0.0637418, No Iterations 81 smoothSolver: Solving for Uz, Initial residual = 0.671639, Final residual = 0.0596769, No Iterations 110 ------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code.. Per user-direction, the job has been aborted. ------------------------------------------------------- -------------------------------------------------------------------------- mpirun detected that one or more processes exited with non-zero status, thus causing the job to be terminated. The first process to do so was: Process name: [[1404,1],1] Exit code: 145 -------------------------------------------------------------------------- |
September 6, 2018, 21:18 |
#2 | |
Peter Baskovich
Rep Power: 12 |
Seeing as the job ran with your previous geometry, I'd suspect that your new geometry is not clean. Have you checked checkMesh results and y+? |
September 6, 2018, 21:23 |
Ed O'Malley
Rep Power: 9 |
Thanks,
I actually just ran checkMesh and got this: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1706 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : v1706-17752679325a Arch : "LSB;label=32;scalar=64" Exec : checkMesh -allTopology -allGeometry Date : Sep 06 2018 Time : 18:19:28 Host : "DESKTOP-1A6ON5E" PID : 1307 Case : /mnt/c/Users/edoma/CFD/ShoeCFD/ShoeCases/LuckBlankCase nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM Warning : From function static Foam::instantList Foam::timeSelector::select0(Foam::Time&, const Foam::argList&) in file db/Time/timeSelector.C at line 274 No time specified or available, selecting 'constant' Create mesh for time = constant Enabling all (cell, face, edge, point) topology checks. Enabling all geometry checks. Time = constant Mesh stats points: 2998206 faces: 8513825 internal faces: 8396763 cells: 2770786 faces per cell: 6.10317 boundary patches: 6 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 2566108 prisms: 23372 wedges: 1830 pyramids: 0 tet wedges: 2599 tetrahedra: 334 polyhedra: 176543 Breakdown of polyhedra by number of faces: faces number of cells 4 21823 5 14203 6 25489 7 20074 8 11736 9 64409 10 343 11 94 12 10677 13 35 14 51 15 7220 16 6 17 7 18 376 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Topological cell zip-up check OK. <<Number of faces with non-consecutive shared points: 3. This might indicate a problem. <<Writing 6 faces with non-standard edge connectivity to set edgeFaces Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology Bounding box frontAndBack 2480 2624 ok (non-closed singly connected) (-0.5 -0.4 -0.5) (1.5 0.4 1) inlet 496 544 ok (non-closed singly connected) (-0.5 -0.4 -0.5) (-0.5 0.4 1) outlet 496 544 ok (non-closed singly connected) (1.5 -0.4 -0.5) (1.5 0.4 1) lowerWall 640 697 ok (non-closed singly connected) (-0.5 -0.4 -0.5) (1.5 0.4 -0.5) upperWall 640 697 ok (non-closed singly connected) (-0.5 -0.4 1) (1.5 0.4 1) shoeCFDlevel 112310 137812 ok (closed singly connected) (0.000437343 -7.86711e-06 0.00262043) (0.343709 0.118546 0.504577) Checking geometry... Overall domain bounding box (-0.5 -0.4 -0.5) (1.5 0.4 1) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (2.61358e-17 -7.37813e-17 1.27339e-15) OK. Max cell openness = 1.11267e-15 OK. Max aspect ratio = 33.7062 OK. Minimum face area = 3.85016e-09. Maximum face area = 0.00260669. Face area magnitudes OK. Min volume = 3.00247e-12. Max volume = 0.000127557. Total volume = 2.39642. Cell volumes OK. Mesh non-orthogonality Max: 64.9836 average: 6.78139 Non-orthogonality check OK. Face pyramids OK. Max skewness = 3.75528 OK. Coupled point location match (average 0) OK. Face tets OK. Min/max edge length = 1.21077e-05 0.0524745 OK. *There are 2401 faces with concave angles between consecutive edges. Max concave angle = 79.9097 degrees. <<Writing 2401 faces with concave angles to set concaveFaces Face flatness (1 = flat, 0 = butterfly) : min = 0.437859 average = 0.999481 *There are 67 faces with ratio between projected and actual area < 0.8 Minimum ratio (minimum flatness, maximum warpage) = 0.437859 <<Writing 67 warped faces to set warpedFaces Cell determinant (wellposedness) : minimum: 8.86824e-06 average: 1.3657 ***Cells with small determinant (< 0.001) found, number of cells: 1223 <<Writing 1223 under-determined cells to set underdeterminedCells ***Concave cells (using face planes) found, number of cells: 65639 <<Writing 65639 concave cells to set concaveCells Face interpolation weight : minimum: 0.0241129 average: 0.483669 ***Faces with small interpolation weight (< 0.05) found, number of faces: 1187 <<Writing 1187 faces with low interpolation weights to set lowWeightFaces Face volume ratio : minimum: 0.0105059 average: 0.922668 Face volume ratio check OK. Failed 3 mesh checks. End |
September 7, 2018, 11:42 |
Ed O'Malley
Rep Power: 9 |
OK, it works now! I realized that it was running OK (results bad but solving) when I had layers turned off and it broke when I added layers to snappyHexMesh. So I decided to just make the layers more robust and changed nSurfaceLayers from 1 to 2 and added more external geometry smoothing iterations. Now it works!
simplefoam |
[Tutorials] Tutorial of how to plot residuals ! | wolle1982 | OpenFOAM Community Contributions | 172 | December 6, 2024 07:20 |
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation | volleyHC | CFX | 5 | April 3, 2016 06:41 |
Problem with an old Simulation | FrankW | CFX | 3 | February 8, 2016 05:28 |
CFX FSI Fatal Error | unbanana | CFX | 0 | October 3, 2015 06:57 |
FSI: Pressure and Normal Force don't match with expected values | Geraud | CFX | 6 | August 21, 2012 16:34 |
