Error when running pimpleFoam: wrong token type -expected Scalar ... 'nan' |
Víctor Balloqui
Rep Power: 8 ![]() |
Hi, I'm an engineering student, and I'm doing my thesis work on the behavior of a wind turbine using some turbulence models. I'm new to using OpenFoam, and I've done some tutorials, but it's costing me a bit to understand and interpret the errors that appear to me. For example, when using the "pimpleFoam" solver after a long time processing the program it falls down and throws me the following error: "wrong token type -expected Scalar, found on line 0 the word 'nan' I hope someone can help me, very grateful. Victor.
Peter Baskovich
Rep Power: 12 ![]() |
Can you post the whole log or an archive of the case folder?
Víctor Balloqui
Dear Peter, thank you for your quick response. In the first post I tried to upload the file folder, but it was impossible due to the low capacity that is allowed to upload files (195.3 KB), and only the STL file in the CONSTANT folder weighs almost 636KB compressed in RAR. I attach the folders 0 and System with the conditions of the problem. thank you sincerely. Victor.
Peter Baskovich
That all looks fine, can you share constant without the geometry and also share a full log of a failed run.
Use: pimpleFoam |& tee log.pimpleFoam If you're not sure how to dump to file. |
richard azouz
Rep Power: 0 ![]() |
Can you post the whole log?
Víctor Balloqui
Hello Peter, The version that went up to the last one I'm working on, since yesterday afternoon is running and still takes half the time. just finish the process I will send the error message that appears with respect to what I like in your answer, "pimpleFoam | & tee log.pimpleFoam", this is a command line that I must execute in the terminal when the process finishes?, Thankful. Hello Richard, thanks for your interest in helping, look there are still no published codes in this forum and as I mentioned before I could not upload the complete case by the size of the geometry, but in the attached link I uploaded the case. Greetings.
https://www.dropbox.com/s/bvg5pzuezl...rbine.zip?dl=0 |
Mohammad Reza
Rep Power: 10 ![]() |
Hello All,
I found my thread related to this discussion: wrong token type - expected word Maybe you can help me with the problem? |
Thuc
Rep Power: 2 ![]() |
Hi Victor,
Did you find out the solution? I also faced the same problem/. |
Modified pimpleFoam solver to MRFPimpleFoam solver | hiuluom | OpenFOAM Programming & Development | 12 | June 14, 2015 21:22 |
Diverging solution in transonicMRFDyMFoam | tsalter | OpenFOAM Running, Solving & CFD | 30 | July 7, 2014 06:20 |
compressible flow in turbocharger | riesotto | OpenFOAM | 50 | May 26, 2014 01:47 |
POSDAT problem | piotka | STAR-CD | 4 | June 12, 2009 08:43 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
