parallelised OpenFoam solver on diverges earlier when the number of cores are higher |
August 24, 2018, 09:43 |
Foad
Rep Power: 9 |
Hi foamers,
I have a model which I'm trying to solve on a cluster (zip file in the attachment). When I divide the problem into 7 segments it solves till 6.74 but when I have 50 segments it stops at 0.72! In fact this is quite random. but in general the higher the number of cores the faster by average it will stop. I run the problem with: Code:
blockmesh decomposePar srun -N 1 --ntasks-per-node=7 --pty bash mpirun -np 7 sonicFoam -parallel -fileHandler uncollated > log.log 2>&1 reconstructPar Code:
[21] --> FOAM FATAL ERROR: [21] Maximum number of iterations exceeded: 100 [21] [21] From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar) const) const [with Thermo = Foam::hConstThermo<Foam::perfectGas<Foam::specie> >; Type = Foam::sensibleInternalEnergy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy>] [21] in file /home/foobar/OpenFOAM/OpenFOAM-v1712/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 73. [21] FOAM parallel run aborting Code:
[21] #5 ? at ??:? [30] #5 ? at ??:? [28] #5 at ??:? [49] #4 Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::correct()? at ??:? [5] #5 at ??:? [36] #5 ?? at ??:? [43] #5 at ??:? [32] #6 __libc_start_main at ??:? [45] #4 at ??:? [44] #5 ? at ??:? [35] #5 at ??:? [40] #5 at ??:? [47] #5 at ??:? [27] #5 at ??:? [31] #5 at ??:? [38] #6 __libc_start_main? at ??:? [11] #5 at ??:? [41] #5 at ??:? [25] #5 at ??:? [42] #6 at ??:? [34] #6 __libc_start_main__libc_start_main? at ??:? [24] #5 at ??:? [9] #5 at ??:? [1] #5 at ??:? [48] #5 in "/lib/x86_64-linux-gnu/libc.so.6" [3] #7 at ??:? [29] #5 at ??:? [10] #5 at ??:? [26] #6 __libc_start_main at ??:? [23] #6 __libc_start_main? at ??:? [33] #5 ?? at ??:? [4] #5 ?? in "/lib/x86_64-linux-gnu/libc.so.6" [32] #7 ??? at ??:? [39] #5 ? at ??:? [30] #6 __libc_start_main? at ??:? [46] #5 ? in "/lib/x86_64-linux-gnu/libc.so.6" [38] #7 ? at ??:? [37] #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [42] #7 ? at ??:? [28] #6 __libc_start_main? in "/lib/x86_64-linux-gnu/libc.so.6" [26] #7 ?? in "/lib/x86_64-linux-gnu/libc.so.6" ?[34] #7 at ??:? [21] #6 __libc_start_main????? at ??:? [43] #6 __libc_start_main? in "/lib/x86_64-linux-gnu/libc.so.6" [23] #7 at ??:? [5] #6 __libc_start_main at ??:? [47] #6 __libc_start_main at ??:? [44] #6 __libc_start_main at ??:? [35] #6 __libc_start_main at ??:? [45] #5 __libc_start_main at ??:? [27] #6 __libc_start_main in "/lib/x86_64-linux-gnu/li?bc.so.6" [30] #7 ?? in "/lib/x86_64-linux-gnu/libc.so.6" [37] #7 at ??:? [49] #5 ?? at ??:? in "/lib/x86_64-linux-gnu/libc.so.6" [28] #7 at ??:? [24] #6 __libc_start_main-------------------------------------------------------------------------- MPI_ABORT was invoked on rank 3 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- at ??:? [36] #6 __libc_start_main at ??:? [1] #6 __libc_start_main at ??:? [40] #6 __libc_start_main? at ??:? at ??:? [33] #6 __libc_start_main[10] #6 __libc_start_main at ??:? [31] #6 __libc_start_main at ??:? [48] #6 __libc_start_main at ??:? [29] #6 __libc_start_main at ??:? [9] #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" in "/lib/x86_64-linux-gnu/libc.so.6" [27] #7 [43] #7 at ??:? [39] #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [5] #7 at ??:? [25] #6 __libc_start_main at ??:? [4] #6 at ??:? [41] #6 __libc_start_main__libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [47] #7 ?? at ??:? at ??:? [11] #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [44] #7 at ??:? in "/lib/x86_64-linux-gnu/libc.so.6" [35] #7 at ??:? ?? at ??:? [weleveld:20500] 3 more processes have sent help message help-mpi-api.txt / mpi-abort [weleveld:20500] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages I would appreciate if you could let me know what is the problem and how I can solve it. |
August 29, 2018, 13:12 |
Michael Alletto
Rep Power: 16 |
I think this is not unusual since with increasing number of processors the solution becomes more and more decoupled
August 29, 2018, 18:17 |
Foad
Rep Power: 9 |
September 5, 2018, 02:53 |
TWB
Rep Power: 19 |
Hi, I have a similar problem but opposite of yours - Running at 288 cores, it diverges but at 600 cores, I got a converged solution:
Problem diverges or not depending on procs number |
diverge, mpi, openfoam, slurm, sonicfoam |
LES, Courant Number, Crash, Sudden | Alhasan | OpenFOAM Running, Solving & CFD | 5 | November 22, 2019 02:05 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
