Running OpenFOAM on a Cluster
Like Tree8Likes
Old   August 23, 2018, 15:15
Faraz
feacluster is on a distinguished road
Originally Posted by Rishab View Post
when i type "source /path/toopenfoam/installation/etc/bashrc" this is what i get:-
bash: /path/toopenfoam/installation/etc/bashrc: No such file or directory
This you have to edit to customize to your installation.. It was not meant to be copy/pasted.. read it again.
feacluster is offline   Reply With Quote
Old   August 24, 2018, 08:22
Rishab.G.Hombal
Rishab is on a distinguished road
Hi
when i type "mpirun -np 6 -hostfile machines simpleFoam -parallel" this is what i get:-
[mpiuser-HP-ProDesk-400-G2-MT-TPM-DP:20848] [[33493,0],0] usock_peer_send_blocking: send() to socket 41 failed: Broken pipe (32)
[mpiuser-HP-ProDesk-400-G2-MT-TPM-DP:20848] [[33493,0],0] ORTE_ERROR_LOG: Unreachable in file oob_usock_connection.c at line 316
[mpiuser-HP-ProDesk-400-G2-MT-TPM-DP:20848] [[33493,0],0]-[[33493,1],0] usock_peer_accept: usock_peer_send_connect_ack failed
mpirun was unable to find the specified executable file, and therefore
did not launch the job. This error was first reported for process
rank 3; it may have occurred for other processes as well.
NOTE: A common cause for this error is misspelling a mpirun command
line parameter option (remember that mpirun interprets the first
unrecognized command line token as the executable).
Node: client1
Executable: /opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/simpleFoam
3 total processes failed to start
when i type "mpirun -np 6 -hostfile machines foamJob simpleFoam -parallel" this is what i get:-
Application : simpleFoam
Executing: /opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/simpleFoam -parallel > log 2>&1 &
Node: client1
Executable: /opt/openfoam6/bin/foamJob
Along with a log file which says :-
It looks like MPI_INIT failed for some reason; your parallel process is
likely to abort. There are many reasons that a parallel process can
fail during MPI_INIT; some of which are due to configuration or environment
problems. This failure appears to be an internal failure; here's some
additional information (which may only be relevant to an Open MPI
developer):
ompi_mpi_init: ompi_rte_init failed
--> Returned "(null)" (-43) instead of "Success" (0)
*** An error occurred in MPI_Init_thread
*** on a NULL communicator
*** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort,
*** and potentially your MPI job)
[mpiuser-HP-ProDesk-400-G2-MT-TPM-DP:20554] Local abort before MPI_INIT completed completed successfully, but am not able to aggregate error messages, and not able to guarantee that all other processes were killed!
Rishab is offline   Reply With Quote
Old   August 24, 2018, 09:40
Rishab.G.Hombal
yes i did customise it and when i type "source /opt/openfoam6/etc/bashrc" nothing happens i dont get any output
then when i type "mpirun -np 6 -hostfile machines simpleFoam -parallel" this is what i get:-
[mpiuser-HP-ProDesk-400-G2-MT-TPM-DP:03141] [[57312,0],0] usock_peer_send_blocking: send() to socket 39 failed: Broken pipe (32)
[mpiuser-HP-ProDesk-400-G2-MT-TPM-DP:03141] [[57312,0],0] ORTE_ERROR_LOG: Unreachable in file oob_usock_connection.c at line 316
[mpiuser-HP-ProDesk-400-G2-MT-TPM-DP:03141] [[57312,0],0]-[[57312,1],0] usock_peer_accept: usock_peer_send_connect_ack failed
Node: client
Old   August 24, 2018, 10:21
Faraz
I don't believe that is supposed to produce any output. It just sets the environment varibles. Put that source line in the bashrc of your master and slave node.
For example here's how the bashrc file looks like for me:
source /opt/apps/OpenFOAM/OpenFOAM-v1712/etc/bashrc
Old   August 24, 2018, 11:07
Rishab.G.Hombal
Hi
yes the line is there in bash file in both nodes ie master and client
source /opt/openfoam6/etc/bashrc this is the line in my case
Old   August 24, 2018, 11:47
Faraz
Rank 3 is the process that starts on the slave. So probably some paths are different on the slave node. Is /opt a NFS share or did you install it separately on both machines?
At this point I would remove the installation from the slave and just make /opt an NFS share.
Old   August 25, 2018, 01:37
hokhay is on a distinguished road
Hi
Just to remind you that the source line needs to place at the first line in the bashrc file. Did you do that?
hokhay is offline   Reply With Quote
Old   August 25, 2018, 08:11
Rishab.G.Hombal
Hi,feacluster
opt is not a nfs shared....i have not installed nfs ive installed openfoam separately inside opt
Old   August 25, 2018, 08:14
Rishab.G.Hombal
hi,hokhay
yes i placed the source line in the first line of the bash file and also in etc/profile and also in ~/.profile this did the trick thanks a lot for you support feacluster and hokhay! u guys are my heroes!
Old   August 25, 2018, 08:21
Rishab.G.Hombal
Hi
the solver is running but i ran out of memory in just 10 iterations! can anyone explain why this is happening?
my case has approximately 7 million cells and my computer config is :-
4GB RAM
500GB HD
4core i5 Processor running at 3.8GHz ie four physical cores and two logical cores
i get a dialogue box after 10 iterations saying simpleFoam stopped unexpectedly because it ran out of memory!
if i have to increase memory what should i upgrade in my computers!?
my decomposeParDict file has the distributed option set to "no" is this causing this problem?
Old   August 25, 2018, 15:41
I think it's just purely too little RAM and 7 millions cell is not small number. My rough guess for 4GB ram, you maybe able to run 2millions cell simulation.
To be honest, your PC is not up to the job for practical CFD. A 7 millions cells sim would take at least 2 days to complete, depending on the convergence rate. You need to get a brand new PC with at least 16GB Ram
Old   August 25, 2018, 18:54
Rishab.G.Hombal
Hi
can you please explain a way to calculate these things maybe not exactly but roughly because this is just a coarse mesh and i will significantly refine my mesh for grid independence which will also increase the number of cells in future and i will also do some fluid structure interaction simulation.
so if i need to upgrade to a new computer i need to decide the specs, and im open to even buying a server or setup another cluster whichever gives me a better performance.
all i know is that if the number of cells reduce to less than 50k cells per processor openfoam does not solve it in parallel. my target is to solve 30 million cells in less than 2 hours. The university im studying right now is willing to fund for the setup.
so please advice and ur inputs and suggestions is highly appreciated.
regards
rishab
Old   August 26, 2018, 00:28
I don't think there is any way to calculate this. It is just from my experience.
For your reference, I am running a car aerodynamics steady state simulation with 35 millions cell on 12 server computers with total of 192 cores and this configuration takes about 18 hours to run 10000 iterations. They are 6 year old servers with E5-2650 cpu. The new AMD EYPC cpu could easily double the performance.
To finish a 30 millions cell sim in 2 hours, I guess you may need more powerfull servers than what I have and your simulation needs to convergence with less iterations. It is really case dependence.
Old   August 26, 2018, 08:12
Rishab.G.Hombal
so when u say server PC what do u exactly mean by it do u literally mean server or is it a PC if so can u please tell me the specs and how many memory slots for a 16core cpu and so on?
Old   August 26, 2018, 15:02
I mean server. The one I am using is PowerEdge R620. It is a dual cpu computer and total of 16 Ram slots. You can find the spec from Dell website. Also OpenFoam is I/O intensitive software, which means the memory bandwidth has a larger impact on performance than CPU.
I suggest you to read the following paper.
https://www.researchgate.net/publica...and_Don'ts
Old   August 27, 2018, 14:34
Faraz
Interesting, I don't have mine in the first line. Here's what my bashrc looks like:
source /opt/intel/compilers_and_libraries/linux/mpi/intel64/bin/mpivars.sh
export LD_LIBRARY_PATH=/opt/apps/intel:$LD_LIBRARY_PATH
export I_MPI_FABRICS=shm:dapl
export I_MPI_DAPL_PROVIDER=ofa-v2-ib0
export I_MPI_DYNAMIC_CONNECTION=0
Encountering an error while running a case in cluster using openfoam dnsuman Main CFD Forum 2 August 6, 2018 02:35
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 14:36
[OpenFOAM.org] How to get OpenFoam compiled on a cluster with CentOS 6.5 and no root permissions hulli OpenFOAM Installation 2 November 6, 2014 19:01
OpenFOAM parallel running error in cluster vishal_s OpenFOAM Running, Solving & CFD 5 March 11, 2014 16:11
Something weird encountered when running OpenFOAM in parallel on multiple nodes xpqiu OpenFOAM Running, Solving & CFD 2 May 2, 2013 05:59
