Advective BC with specified direction (outlet-velocity) |
August 19, 2018, 20:50 |
Gazi Yavuz
Rep Power: 8 |
Hello dear all,
I try to simulate flow over a Low Pressure Turbine Blade. For my case, i use pisoFoam solver in a full structured domain having cyclic conditions on two faces along y direction, inlet and outlet along x direction, a casing wall and symmetryPlane along z direction. I ran a few seconds of calculation in OpenFoam and checked the analysis but noticed that there is a problem about the direction that flow goes through at the outlet. At the inlet For the velocity, i have defined Code:
Inlet { type fixedValue; value uniform ( 0.79 0.61 0); } Code:
Outlet { type advective; } I contemplated that i could perhaps change something about the outlet for P however it s a scalar quantity, to which i cannot define direction. It seems the trick is about the velocity. Do you know how to specify a direction to the outlet for advective bc or have any other solution to that problem? I just should direct the flow, should not specify a value. Best regards. |
advective bc, les, pisofoam |
Advective BC for velocity | D.B | OpenFOAM Running, Solving & CFD | 1 | January 18, 2016 02:09 |
Incompressible flow velocity: outlet faster than inlet | Xuekun | Main CFD Forum | 13 | October 30, 2015 14:52 |
Advective BC: local velocity? | dany | OpenFOAM Running, Solving & CFD | 0 | July 3, 2009 08:48 |
Outlet velocity boundary condition | Jay | FLUENT | 4 | December 15, 2002 08:27 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
