Joaquín Neira
Rep Power: 8 ![]() |
Hello, I'm working on a modified solver and intermediate library, and it works (or used to work) fine.
The thing is that when I changed to OF6, I get this result: http://ibb.co/cHxS5z (could not attach photo) As you can see, there are short particle paths, which belong to the same particle as the long ones. I'm running my case in parallel and my reconstruct command is: reconstructPar -noFields -lagrangianFields '(age U positions)' |
duplicate, lagrangian, of6 |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
Aurelia Vallier, MultiScale, Eulerian-Lagrangian Couplling, VOF-LPT, Lagrangian, | saddy | OpenFOAM Programming & Development | 0 | August 9, 2017 14:28 |
converse lagrangian field to eulerian | Jan_B | OpenFOAM Programming & Development | 0 | August 13, 2015 13:11 |
Problem in3D model processing | mebinitap | OpenFOAM | 2 | December 12, 2014 04:40 |
