Free decaying mass-spring system - pimpleDyMFoam |
August 15, 2018, 21:58 |
Fredi Cenci
Rep Power: 10 |
Hello all,
My problem is a cylinder attached to a spring (no damping). The cylinder is immersed on air. It should result in a sine with little decay (because water viscosity). However, what I find is a small amplification of the sine, seems like the problem is gaining energy somehow. Attached are pictures of the transverse amplitude through time. First, I thought the problem was mesh resolution and residuals, but decreasing these factors doesn’t help. Secondly, I tried to put a little damping (C = zeta*wn*2*m), with zeta = 0.5%. But the results give me a decay with zeta = 0.14%. I have a guess that the problem may be my BC. I put a fixedValue inlet with velocity (0,0,0) and all domain with zero velocity as well. Here is the link ok my testcase. https://drive.google.com/file/d/1Fmm...UIkeKyhJ7/view May someone give me a hint of what could be the issue? Thanks in advance. 39146173_1893991114026776_2290834838703308800_o.jpg 39188348_1893991104026777_1563691592680734720_o.jpg |
August 3, 2019, 10:07 |
Rep Power: 8 |
Hi! Excuse me, can I know how to get the oscillating amplitude change or the spring length change? like your pic showing the change of y?
Best regards, ZHI CHENG |
August 4, 2019, 00:20 |
Rep Power: 8 |
High pressure values at inlet and Loss of Mass flow at AMIs -- pimpleDymFoam | coolcrasher | OpenFOAM Running, Solving & CFD | 3 | April 18, 2016 03:51 |
SprayFoam: incorrect mass in system as mesh is refined | banji | OpenFOAM Running, Solving & CFD | 0 | April 6, 2016 11:40 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 19:56 |
free code about "system identification" | ztdep | Main CFD Forum | 1 | April 14, 2007 21:58 |
Code with reliable free surface capability in a rotating system | Subhasish Roy Choudhury | Main CFD Forum | 1 | September 4, 1998 19:47 |
