DeltaT is going to extremely low values while running InterFoam |
August 6, 2018, 15:25 |
Charles
I have been trying to run a simulation on a geometry using the InterFoam solver. after an hour or so, the delta T value gradually reaches to low values in the range of 1e-100 from 1e-05 and simulation crashes. I have been trying to fix this problem for a long time, but is unsuccessful till date. I am adding my controlDict and my checkMesh results along with this message. Any help will be appreciated. Thank you in advance ControlDict Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application interFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 0.1; deltaT 1e-5;//5e-5; writeControl adjustableRunTime; writeInterval 1e-4; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression uncompressed; timeFormat general; timePrecision 8; runTimeModifiable yes; adjustTimeStep yes; maxCo 1; maxAlphaCo 1; maxDeltaT 1e-5; // ************************************************************************* // /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 5.x-197d9d3bf20a Exec : checkMesh Date : Aug 06 2018 Time : 20:59:56 Host : "*********" PID : 7919 I/O : uncollated Case : ************************************ nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 22811 faces: 62700 internal faces: 57300 cells: 20000 faces per cell: 6 boundary patches: 8 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 20000 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology left 900 971 ok (non-closed singly connected) inlet_oil 200 231 ok (non-closed singly connected) down 1100 1191 ok (non-closed singly connected) up 400 451 ok (non-closed singly connected) inlet_water 300 331 ok (non-closed singly connected) outlet 500 541 ok (non-closed singly connected) frontAndBack 1600 1732 ok (non-closed singly connected) capillaryWalls 400 462 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (0 0 -0.00215) (0.00765 0.0011 0.002) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-3.17589e-16 -1.19329e-15 4.17605e-16) OK. Max cell openness = 2.25477e-16 OK. Max aspect ratio = 72.7628 OK. Minimum face area = 7.62463e-11. Maximum face area = 3.12396e-08. Face area magnitudes OK. Min volume = 3.81232e-15. Max volume = 1.56198e-12. Total volume = 6.26804e-09. Cell volumes OK. Mesh non-orthogonality Max: 73.2218 average: 14.5284 *Number of severely non-orthogonal (> 70 degrees) faces: 60. Non-orthogonality check OK. <<Writing 60 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. Max skewness = 0.885518 OK. Coupled point location match (average 0) OK. Mesh OK. End |
October 22, 2021, 16:27 |
Vadym Ostanin
I faced the same issue.
Found solution to change "adjustTimeStep yes;" to "adjustTimeStep no;" |
InterFoam parallel running for 48 hours without producing time folders! | alinuman15 | OpenFOAM Running, Solving & CFD | 6 | November 9, 2017 17:13 |
using chemkin | JMDag2004 | OpenFOAM Pre-Processing | 2 | March 8, 2016 22:38 |
AutoGrid Mesh with Extremely Low Run-up | cbrian | Fidelity CFD | 3 | March 7, 2015 04:21 |
Convergence issues in extremely low Re problems | santiagomarquezd | OpenFOAM Running, Solving & CFD | 0 | October 28, 2014 10:53 |
Drag and Lift forces extremely low | João Lourenço | FLUENT | 4 | January 28, 2008 13:25 |
