Simple rectangular open-channel flow
Old   August 6, 2018, 06:08
Default Simple rectangular open-channel flow
Chaewoong Ban
blue8803 is on a distinguished road
I'm using OF 5.x for multiphase flows.
The geometry is simple such as rectangular open channel (not duct flows).
The channel is divided to air part and water part
so the boundries I have to set are inlet_water, inlet_air, outlet_water, outlet_air, walls (sidewall+bottomwall), atmosphere
inlet_water and outlet_water are set by cyclic conditions
and I used the momentumSource (constant/fvOptions) for the driving force (below), without inclination of channel or correction of gravity acceleration.
momentumSource
type patchMeanVelocityForce;
selectionMode all;
patch inlet_water;
fields (U);
Ubar (0.1924 0 0);
However, the simulation results are somewhat strange. the velocity of air part become faster than the water part. So, the air part make the water part accelerate.... I've been trying many BCs for air_inlet & air_outlet, but I'm still very confused..
The details are attached.
https://drive.google.com/open?id=1Cx...5GQcKivKNxsmaX
Please let me knwo what is wrong.
blue8803 is offline   Reply With Quote
Old   August 24, 2018, 09:12
subhankar das
subhankarnits is on a distinguished road
Why did you use cyclic condition?
subhankarnits is offline   Reply With Quote
Old   June 17, 2020, 22:45
Chaewoong Ban
I hope to get a developed flow by using cyclic condition in the rather short domain. But i realized that using the cyclic condition at the interFoam simulation make nonsense in the physical view and cause instability at the free surface interface..
Old   July 9, 2021, 05:11
Loren
loren1205 is on a distinguished road
Did you manage to solve the problem? Could you upload the files, because I have the same case to solve, but I never used multiphase method.
loren1205 is offline   Reply With Quote
bcs, channel flows, interfoam, les, momentumsource
Open Channel flow (Convergence problem) Sama Mohammad Fluent Multiphase 5 September 10, 2019 01:11
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 18:34
Open Channel Flow forsumit FLUENT 0 October 1, 2009 03:01
open channel flow boundary conditions yan FLUENT 0 July 5, 2005 00:36
SIMPLE Scheme for open channel flow ao Main CFD Forum 0 April 6, 2004 17:21
