using heat flux BC on wall in openFOAM 6
Old   August 4, 2018, 15:57
Post using heat flux BC on wall in openFOAM 6
ravi k
ravik21 is on a distinguished road
Hi Foamers,
I was using openFOAM 2.3.1 for a internal hvac problem. I was able to provide heat flux BC
on surfaces using turbulentHeatFluxTemperature BC.
But in openFOAM 6 this BC is no longer supported. What is the alternative for this BC in OF6 ?
I am shifting from OF2.3.1 to 6 because I want to use externalWallHeatFluxTemperature BC
for giving HTC and external temperature on external walls. This is not possible in OF2.3.1
I saw some threads: wallHeatFlux utility for an incompressible case
but didn't got any answer related to OF6.
It looks like there is an utility to do this : wallheatflux-utility, but I want to know what is the native option in OF6 itself.
Thanks,
Ravi
ravik21 is offline   Reply With Quote
Old   August 5, 2018, 11:58
Default Self compilation
Sandeep Pandey
sandeep.pandey is on a distinguished road
Hi Ravi,
I had the same issue while upgraded to OpenFOAM 5.x with
compressible::turbulentHeatFluxTemperature;
Then, I took the same BC from the old version of OpenFOAM and compiled it by myself for OpenFOAM 5.x. As an example, I am attaching my BC for OpenFOAM 5.x (myturbulentHeatFluxTemperature.zip). Compile it as usual by
wclean
and
wmake
It worked fine for me, you can try with OpenFOAM 6.
Bests,
Sandeep
sandeep.pandey is offline   Reply With Quote
Old   August 5, 2018, 16:01
Thumbs up
ravi k
Thanks a lot Sandeep.
I will compile it with openFOAM 6 and will check if it works with OF6 or not.
But I wonder why it was removed in newer versions, there is absolutely no
other alternate boundary condition for turbulentHeatFluxTemperature ?
If really there is no native alternative then it should be added back, because its a frequently required BC for thermal simulations.
Ravi
Old   January 14, 2019, 22:21
Jianrui Zeng
calf.Z is on a distinguished road
I think turbulentHeatFluxTemperature BC is replaced by externalWallHeatFluxTemperature ?
calf.Z is offline   Reply With Quote
externalwallheatflux, openfoam 6, turbulentheatflux, wallheatflux
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
heat flux in openfoam JasonWang3 OpenFOAM Programming & Development 0 September 13, 2015 09:26
Heat transfer BC at wall- why need wall thickness? Julie FLUENT 7 February 3, 2012 22:41
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 23:22
