Gurpreet Singh
Rep Power: 9 ![]() |
Hi Dear OpenFOAM Users,
I am trying to run steady state, incompressible and laminar flow through the circular pipe using OpenFOAM 5.0 version with “simpleFoam” solver. I made an axis-symmetric mesh using Pointwise Meshing tool. The domain is of size ( Length of the pipe=5.0 m and radius of the pipe = 0.1 m ). I gave 150 mesh points in the axial and 10 mesh points in the radial direction. I have calculated the first cell height near the wall = (Radius/38). Input parameters: Velocity at the inlet = 1.0 m/s Density = 1.0 kg/m^3 Dynamics Viscosity = 2.0*10^-3 kg/ms Based on these parameters, calculated Reynolds Number = 100 I run this case for 1000 iterations and the simpleFoam solver is not converging. I tried every other option in the OpenFOAM. When I look at the terminal screen, Pressure, Ux, Uy all three variables are converging except Uz. In z-direction, I defined " wedge " boundary condition like we define empty boundary condition for 2d problems and the solver should not iterate in that direction. I would like to ask the following questions... (1): As I am solving the 2d axis symmetric problem for flow through a circular pipe and the 2d domain is made in the x-y plane, whereas the "wedge" boundary condition is defined in the z-direction. My question is why OpenFOAM is solving for Uz velocity component as I defined this direction as Wedge boundary condition for telling the solver that I am solving for a 2d axis symmetric problem like we define a 2d domain in the Cartesian coordinate system by defining the "empty" boundary condition and OpenFOAM always ignore this direction without solving it. (2): I am new to Pointwise and never tried making axis symmetric mesh on this meshing tool. I just want to know that whether the mesh it self-correct or not? (3) : I tried many ways to make the solver converge but residual of Uz component is not converging I mean not going below the specified residual control for U. That's why the solver is not converging. I am attaching here Pointwise Mesh, terminal output, and the residual graphs. I will be very thankful to you for your valuable suggestions on these questions. MasterfileMesh(150*10) graded.pw.tar.gz SimpleFoam.tar.gz Terminal output.tar.gz |
axissymmetric mesh, simplefoam |
simpleFoam parallel solver & Fluent polyhedral mesh | Zlatko | OpenFOAM Running, Solving & CFD | 3 | September 26, 2014 06:53 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
Harpoon and OpenFoam - Mesh and simpleFoam | scott | OpenFOAM | 4 | September 4, 2009 07:48 |
