August 1, 2018, 10:31 |
impingement jet fluid flow
Rep Power: 11 |
Hi
I am modeling a 2D steady state impingement jet hot air flow, with the buoyantBoussinesqSimpleFoam solver in order to calculate the heat transfer between the hot air and 2 different B.C.: 1) Fixed wall B.C. 2) Moving wall B.C. See the attached sketch for the geometry setup. Is the 2nd B.C. a possibility, as I wish to investigate the effects on the flow and thus heat transfer due to the wall motion? Kind regards! |
August 3, 2018, 18:49 |
Rep Power: 15 |
Yes, the second is a possibility. Simply set the wall velocity to a non-zero fixed value (as opposed to noSlip or a zero fixed value for a stationary wall).
Caelan |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
Fluid Flow into Still Air from Faucet | bladder1996 | Fluent Multiphase | 2 | January 8, 2018 11:50 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 18:38 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 15:32 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
