DDES model OpenFoam
Old   July 27, 2018, 15:12
Question DDES model OpenFoam
Davide
Davide95 is on a distinguished road
Dear Fomers,
I am a newbie and I am struggling to understand how to set up a simulation in OpenFoam with a DDES model.
In the tutorials i found motorbike tutorial ($FOAM_TUTORIALS/incompressible/pisoFoam/LES/motorBike/) which uses DDES but still i am ecountering troubles.
In the tutorial folder i can see a bashfile "Allrun" and two folders : "lesfiles" and "motorbike".
The first folder contains only these files set for a LES case :
fvSchemes
turbulenceProperties
controlDict
fvSolution
The second one basically is like a case with a RANS model where only the mesh is missing.
To what I understood the bashfile called "Allrun" both creates the mesh and starts the simulation.
After running the "Allrun" file a new folder appears which is called "motorbikeLES".
After several hours I had to stop the Allrun process so I don't know exactly what was it doing.
I don't get how I can set up my own case with a DDES model, especially which are the folders required and I don't get if the "Allrun" bash file is necessary or I could start my simulation without it.
Thanks a lot in advance for anyone who will help
Best regards
Davide
Davide95 is offline   Reply With Quote
Old   July 28, 2018, 13:58
Robin Kamenicky
Robin.Kamenicky is on a distinguished road
Hi David,
I have had a look at the bash scripts motorBike/Allrun, motorBike/motorBike/Allrun and also motorBike/lesFiles/Allrun and tried to comment it a bit more. I hope it helps. Have a look.
motorBike/Allrun
#!/bin/sh
cd ${0%/*} || exit 1    # Run from this directory
# Source tutorial run functions
. $WM_PROJECT_DIR/bin/tools/RunFunctions
cloneParallelCase()     #Function to clone a case
    if [ -d $2 ]        #If directory called by second function parameter exists
    then
        echo "Case already cloned: remove case directory $2 to clone"
    else
        echo "Cloning $2 case from $1 in parallel mode"
        mkdir $2                # Make a directory called by second function parameter
        cpfiles="processor* system constant"    #Following code is to copy directories processor* system/ constant/ from a directory passed to the function by first parameter to the directory passed to the function by second parameter
        for f in $cpfiles
        do
            cp -r $1/$f $2
        done
    fi
# Do the Spalart-Allmaras steady-state case
(cd motorBike && foamRunTutorials)              #Command executed in subshell runs the motorBike case using motorBike/motorBike/Allrun
if ! isTest $@          #if isTest is falls. $@ stands for all parameters from $1 passed to the isTest function. isTest is a function from RunFunctions script.
then
    # Clone the steady-state case to the LES case
    cloneParallelCase motorBike motorBikeLES    #Call the function cloneParallelCase where $1 is motorBike and $2 is motorBikeLES
 # Do the LES case
    cp lesFiles/Allrun motorBikeLES/            #The lesFiles/Allrun needs to be checked since it is copied in to motorBikeLES
    (cd motorBikeLES && foamRunTutorials)       #running the motorBikeLES/Allrun in subshell
fi
#!/bin/sh
# copy motorbike surface from resources directory
cp $FOAM_TUTORIALS/resources/geometry/motorBike.obj.gz constant/triSurface/
# Make dummy 0 directory
mkdir 0                 #blockMesh needs the 0 directory, does not matter what is inside
runApplication blockMesh        #run blockMesh
cp system/decomposeParDict.hierarchical system/decomposeParDict #copy decomposeParDict needed to decomposition and subsequent parallel run
runApplication decomposePar     #decomposition for parallel run
cp system/decomposeParDict.ptscotch system/decomposeParDict
runParallel snappyHexMesh -overwrite            #meshing with snappyHexMesh
find . -type f -iname "*level*" -exec rm {} \;
ls -d processor* | xargs -I {} rm -rf ./{}/0    #remove from processors 0 directory since it is dummy
ls -d processor* | xargs -I {} cp -r 0.orig ./{}/0      #copy to processors 0.orig as 0/
runParallel renumberMesh -overwrite     #renumber the processors after decomposition to make the simulation more efficient
runParallel potentialFoam -initialiseUBCs       #initiate U velocity BCs with potentialFoam in parallel
runParallel `getApplication`    #run pisoFoam in parallel
#!/bin/sh
# Set-up the LES case
cp ../lesFiles/fvS* ../lesFiles/controlDict system/     #Copy fvSchemes, fvSolution and controlDict to system/
cp ../lesFiles/turbulenceProperties constant/           #Copy turbulenceProperties to constant/
ls -d processor* | xargs -I {} rm -rf ./{}/0            #Remove 0/ from processor*
ls -d processor* | xargs -I {} mv ./{}/500 ./{}/0       #Rename 500/ to 0/ in processor*
ls -d processor* | xargs -I {} rm -rf ./{}/0/uniform    #Remove processor*/0/uniform
runParallel pisoFoam                                    #Run pisoFoam in parallel
runApplication reconstructParMesh -constant -mergeTol 1e-6      #Reconstract mesh
runApplication reconstructPar                           #Reconstract fields
Overall, there are a few main steps in the Allruns:
  • copy motorBike surfaceinto the case
  • mesh it with snappyHexMesh
  • initiate U BCs with potentialFoam
  • run the motorBike case with pisoFoam
  • make the motorBikeLES case and initiate it with results of motorBike case
Everything is done in parallel.
Let me know if you have some further questions. It might seems to be quite complex because you run the RANS to initiate LES simulation. You can also make a case without initiating it with LES, if you are able to give good ICs and BCs
Robin
Robin.Kamenicky is offline   Reply With Quote
Old   July 28, 2018, 14:44
Smile
Davide
Dear Robin
Thanks a lot for your reply, it has been extremely enlightening.
As far as I understand if I want to perform a DDES simulation (presuming I can provide appropiate BC) i just need to replace the files in lesproperties with the ones in motorbike/motorbike, provide a valid mesh and adjust the files in 0 in order to match with the mesh.
Another possible approach would be to perform RANS and then provide the results as a starting point for the LES simulation.
The Allrun bash script automates this process.
Am I right?
Thanks again for your avaibility, you have been extremely useful.
Best regards
Davide
Old   July 28, 2018, 15:13
Robin Kamenicky
Hi Davide,
I am glad it helps
If you want to perform LES simulation with SpalartAllmarasDDES. The main think is the lesFiles/turbulenceProperties.
In this case it has been provided also particular setup in fvSchemes, fvSolution, controlDict, however those files from lesFiles are not inevitable. Despite that I would definitely recommend to use them.
So regarding to your words. You need to do it in opposite way copy files from lesFiles to motoBike/motorBike on they particular place.
That is right
Kind regards,
Robin
Old   July 28, 2018, 20:36
Davide
Originally Posted by Robin.Kamenicky View Post
Hi Davide,
I am glad it helps
That is right
Kind regards,
Robin
Actually I wrote it the other way round but replacing the les files in the motorbike folder is what i meant! =D
Anyway I managed to start one simulation with the DDES model.
Thanks for all the help provided! Super kind and useful
ddes, hrl, set up
Using oneEqEddy model in openFoam 4 THohman OpenFOAM Pre-Processing 1 February 11, 2017 10:31
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
about Subgrid-scale model impecca OpenFOAM Running, Solving & CFD 4 December 20, 2013 11:36
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
