MRF simpleFoam problem
Old   July 24, 2018, 08:48
Default MRF simpleFoam problem
Tommaso Pascon
Pervispasco is on a distinguished road
Hi everyone,
in the next few months I'm going to simulate a 2D VAWT with openfoam. I would like to do both steady state and unsteady simulations. I have already clear how the sliding mesh technique is implemented in openfoam, but I'm still struggling with the MRF steady approach.
To have a better understanding of the problem I decided to replicate the mixervessel tutorial from scratch.
I copied the case folder and deleted the original mesh. I created an identical copy with gmsh software using an unstructured mesh.
I defined a rotor volume including the 4 internal yellow zones and a stator volume with the remaining 4 yellow areas.
You can see the original mesh and my variation in the following pictures:
I defined the different patches as per the original tutorial case.
I ran the simulation for both case and the original converged around 700 iterations faster than my variation (residuals 10e-4).
Comparing the results i got similar values for U while for all the other variables i very different behaviour (I.E the pressure field in the next picture):
Is there something I'm missing in the definition of the rotor regions by MRF file?
Thanks in advance for any suggestion.
Pervispasco is offline   Reply With Quote
mixervessel, mrf, simplefoam, vawt
simpleFoam - MRF - Wind Turbine Blade Aeronautics El. K. OpenFOAM Running, Solving & CFD 7 June 2, 2021 20:06
Simplefoam Convergence Problem after Scaling by 0.001 CFDy OpenFOAM Running, Solving & CFD 4 July 23, 2018 04:27
Non-Physical Result in MRF simpleFoam chaz OpenFOAM Running, Solving & CFD 0 March 8, 2018 14:36
Particle tracking problem with MRF bioexplore CFX 8 September 22, 2013 17:13
simpleFoam: Problem with k-omega Model near Wall okroud OpenFOAM Running, Solving & CFD 0 June 13, 2012 11:13
