turbulentHeatFluxTemperature doesn't work with buoyantBoussinesqPimpleFoam |
January 22, 2019, 18:40 |
#21 |
Rep Power: 15 |
I am not sure why you are getting different results. However, for your energy balance at the walls you should compute it as you apply it -- ie with the temperature gradient you apply (assuming you resolve the wall) and balance energy fluxes.
Caelan |
RP_Set_Integer does not work in parallel | 86lolo | Fluent UDF and Scheme Programming | 2 | July 3, 2014 12:37 |
Does CX_Interpret_String work in parallel? | 86lolo | Fluent UDF and Scheme Programming | 2 | June 30, 2014 05:36 |
Companies that lease software & hardware for cloud-based work? | Catthan | ANSYS | 0 | June 18, 2014 11:53 |
Why do the Plant library cases don't work? | Alumna | Phoenics | 6 | June 22, 2004 13:08 |
why my In-Form doesn't work? | green | Phoenics | 2 | May 27, 2004 22:03 |
